[petsc-users] How can I get the global integer ids in a label?
Thu Dec 6 21:07:51 CST 2018
On Thu, Dec 6, 2018 at 9:53 PM leejearl <leejearl at mail.nwpu.edu.cn> wrote:
> Hi, Matt:
> I find that the periodic boundary is specified in the following way
> DMPlexCreateBoxMesh <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexCreateBoxMesh.html#DMPlexCreateBoxMesh>(comm, dim, user->simplex, user->cells, NULL, NULL, user->periodicity, interpolate, dm).
> If I use an exo file, how does the periodicity is specified?
> If your exodus file does not already have a periodic topology, I have  no
way
of doing this. GMsh has periodicity in its format, so we support reading
that in
and fixing the topology.
   Matt
> Thanks
> Leejearl
> On Thu, 2018-12-06 at 21:42 -0500, Matthew Knepley wrote:
> Yes
>    Matt
> On Thu, Dec 6, 2018 at 9:28 PM leejearl <leejearl at mail.nwpu.edu.cn> wrote:
> Hi Matt:
> > > My mesh file is "*.exo". Can it works
> > > fineDMPlexCreateBoxMesh_Simplex_Internal?
> Thanks.
> leejearl
> On Thu, 2018-12-06 at 21:20 -0500, Matthew Knepley wrote:
> On Thu, Dec 6, 2018 at 9:08 PM leejearl <leejearl at mail.nwpu.edu.cn> wrote:
> Hi, Matt:
> Is the code in following page?
> /petsc-master/src/snes/examples/tutorials/ex12.c.html
> https://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex12.c.html
>   Matt
> Thanks
> leejearl
> On Thu, 2018-12-06 at 20:26 -0500, Matthew Knepley wrote:
> On Thu, Dec 6, 2018 at 8:06 PM leejearl <leejearl at mail.nwpu.edu.cn> wrote:
> Hi Matt:
> Thank you for your helps. I want to implement the periodic boundary in
> dmplex. For a cell or face, the donor cell or face might be not distributed
> in the same local dm. Maybe I should ask that how
> can I implement the topology of the periodic boundary in demplex.
> Plex directly encodes a periodic topology. For example, with a circle,
> each vertex is connected
> to two neighbors. There are example with periodic boundary conditions like
> SNES ex12.
>  Thanks,
>     Matt
> Thanks again for your kind reply.
> leejearl
> On Thu, 2018-12-06 at 12:02 -0500, Matthew Knepl
> On Thu, Dec 6, 2018 at 9:47 AM leejearl via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi, Petsc developer:
>         I have a problem for helps.
>         There is a dmplex object, and I have distribute it use the
> routine DMPlexDistribute(). Then, I want to get the global integer ids
> in the label "Face Sets". The code is as follow,
>      ierr = DMGetLabelIdIS(dm, "Face Sets", &bcIdIS);CHKERRQ(ierr);
> The values of bcIdIs are the local integer ids. How can I get the
> global integer ids.
> The problem also can be described as follow. The global ids might look
> likes
> IS Object: 1 MPI processes
>   type: general
> Number of indices in set 4
> 0 1
> 1 4
> 2 3
> 3 2
> But after the dm is distributed, I can only get the local ids as follow
> using the routine "DMGetLabelIdIS"
>   type: general
> [0] Number of indices in set 3
> [0] 0 1
> [0] 1 2
> [0] 2 4
> How can I get the global integer ids in a label after the dm is
> distributed?
> Any helps are appreciate!
> You can make a conversion from local point numbers to global point numbers
> using
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexCreatePointNumbering.html
> You could even make a replacement DMLabel with the global point numbers,
> but I think the win would be small
> or nonexistent for most cases.
>   Thanks,
>     Matt
> Thanks
> leejearl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181206/b603e926/attachment-0001.html>
