[petsc-users] PETSc Data structures on GPU
Thu Dec 6 14:15:11 CST 2018
On Thu, Dec 6, 2018 at 2:43 PM Weston, Brian Thomas via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> For parallel computations on the CPU, we allocate our own vectors and then
> give PETSc a point to our vectors using VecCreateMPIWithArray. For
> computations only on the GPU, we allocate vectors on the GPU and we’d like
> to do the same thing and give PETSc a pointer to our vector.
> 1. Does VecCreateMPICUDAWithArray have the same functionality and will it
> only operate on the GPU?
Karl will know.
> 2. Are there ways to ensure that our PETSc matrices and vectors only live
> on the GPU (as to avoid data transfer from CPU to GPU)?
The coherence strategy does not activate unless you ask for the CPU
version. It should do what you want if you only execute GPU operations.
> 3. Lastly, if in the future we move to AMG clusters, will these PETSc CUDA
> commands still work?
AMD? The viennacl implementation will work on AMD. Everything looks the
same, and you could try that out on your Nvidia hardware as well.
    Matt
> Thanks,
> Brian
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181206/1fbb5bdd/attachment.html>
