[petsc-users] Fortran: undefined reference to petscsfdistributesection
Mon Dec 3 14:56:47 CST 2018
On Mon, Dec 3, 2018 at 3:40 PM Danyang Su <danyang.su at gmail.com> wrote:
> On 2018-12-03 12:03 p.m., Matthew Knepley wrote:
> On Mon, Dec 3, 2018 at 2:27 PM Danyang Su <danyang.su at gmail.com> wrote:
>> Hi Matt,
>> Thanks.
>> BTW: DmPlexGetVertexNumbering now can work using the latest develop
>> version. But the index is not in natural ordering when DMSetUseNatural is
>> called. That's why I want to use PetscSFDistributeSection to check if I
>> miss anything in the code.
> Can you explain that a little more? Maybe you can just push forward what
> you want using the migrationSF.
> Hi Matt,
> Since I cannot figure what is wrong or missing in my code, I followed an
> old ex26.c example in src/dm/impls/plex/examples/tests to create similar
> code as shown below to test global to natural ordering. The code may be
> ugly with unnecessary functions in it. Using DmPlexGetVertexNumbering, I
> can get the value but it is not in natural order, instead, it is still in
> default PETSc order without calling DMSetUseNatural(dm,PETSC_TRUE,ierr).
I do not understand what you are doing below. You just need to call
    ierr = DMSetUseNatural(dm,PETSC_TRUE);CHKERRQ(ierr);
    ierr = DMPlexDistribute(dm,0,&migrationSF,&pdm);CHKERRQ(ierr);
    if (pdm) {
      ierr = DMPlexSetMigrationSF(pdm,migrationSF);CHKERRQ(ierr);
and the DMGlobalToNaturalBegin/End() should work.
     Matt
>           if (rank == 0) then
>             call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,num_cells,
> num_nodes,num_nodes_per_cell,    &
>                                           Petsc_False,dmplex_cells,ndim,
> dmplex_verts,dm,ierr)
>             CHKERRQ(ierr)
>           else
>             call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,
> 0,num_nodes_per_cell,    &
> Petsc_False,dmplex_cells,ndim,dmplex_verts,dm,ierr)
>             CHKERRQ(ierr)
>           end if
>           if (nprocs > 1) then
>             call DMSetUseNatural(dm,PETSC_TRUE,ierr)
>             CHKERRQ(ierr)
>           end if
>           call DMPlexDistribute(dm,stencil_width,                &
> migrationsf,distributedMesh,ierr)
>           CHKERRQ(ierr)
>           if (distributedMesh /= PETSC_NULL_DM) then
>             call PetscSFCreateInverseSF(migrationsf,migrationsf_inv,ierr)
>             CHKERRQ(ierr)
>             call
> DMCreateGlobalToNatural(distributedMesh,migrationsf,migrationsf_inv,ierr)
>             CHKERRQ(ierr)
>             call DMGetSection(distributedMesh,section,ierr)
>             CHKERRQ(ierr)
>             call PetscSectionCreate(Petsc_Comm_World,section_seq,ierr)
>             CHKERRQ(ierr)
>             call PetscSFDistributeSection(migrationsf_inv,section,       &
>                         PETSC_NULL_INTEGER,section_seq,ierr)
>             CHKERRQ(ierr)
>             call DMPlexCreateGlobalToNaturalSF(distributedMesh,          &
>                        section_seq,migrationsf,sf_natural,ierr)
>             CHKERRQ(ierr)
>             call DMSetUseNatural(distributedMesh,PETSC_TRUE,ierr)
>             CHKERRQ(ierr)
>             call PetscSFDestroy(migrationsf,ierr)
>             CHKERRQ(ierr)
>             call PetscSFDestroy(migrationsf_inv,ierr)
>             CHKERRQ(ierr)
>           end if
> Thanks,
> Danyang
>   Thanks,
>      Matt
>> Regards,
>> Danyang
>> On 2018-12-03 5:22 a.m., Matthew Knepley wrote:
>> I need to write a custom Fortran stub for this one. I will get it done as
>> soon as possible.
>>   Thanks,
>>     Matt
>> On Sat, Dec 1, 2018 at 7:16 PM Danyang Su via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi All,
>>> I got a simple compilation error when use PetscSFDistributeSection in
>>> Fortran. It looks like the required head files are included and the
>>> parameters are correctly defined. However, when compile the code, I got
>>> error undefined reference to `petscsfdistributesection_'. The code is
>>> shown below. Did I miss anything here?
>>> #include <petsc/finclude/petscsys.h>
>>> #include <petsc/finclude/petscvec.h>
>>> #include <petsc/finclude/petscdm.h>
>>> #include <petsc/finclude/petscdmplex.h>
>>>        use petscsys
>>>        use petscvec
>>>        use petscdm
>>>        use petscdmplex
>>>        implicit none
>>>        PetscSection ::  section, section_seq
>>>        PetscSF :: migrationsf_inv, sf_natural
>>>        Vec :: vec_global, vec_natural
>>>        PetscErrorCode :: ierr
>>>        CHKERRQ(ierr)
>>>            CHKERRQ(ierr)
>>> Thanks,
>>> Danyang
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181203/7648fd41/attachment-0001.html>
