[petsc-users] Fortran: undefined reference to petscsfdistributesection
Danyang Su
danyang.su at gmail.com
Mon Dec 3 14:40:21 CST 2018
On 2018-12-03 12:03 p.m., Matthew Knepley wrote:
> On Mon, Dec 3, 2018 at 2:27 PM Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
> Hi Matt,
> Thanks.
> BTW: DmPlexGetVertexNumbering now can work using the latest
> develop version. But the index is not in natural ordering when
> DMSetUseNatural is called. That's why I want to use
> PetscSFDistributeSection to check if I miss anything in the code.
> Can you explain that a little more? Maybe you can just push forward
> what you want using the migrationSF.
Hi Matt,
Since I cannot figure what is wrong or missing in my code, I followed an
old ex26.c example in src/dm/impls/plex/examples/tests to create similar
code as shown below to test global to natural ordering. The code may be
ugly with unnecessary functions in it. Using DmPlexGetVertexNumbering, I
can get the value but it is not in natural order, instead, it is still
in default PETSc order without calling DMSetUseNatural(dm,PETSC_TRUE,ierr).
if (rank == 0) then
call
DMPlexCreateFromCellList(Petsc_Comm_World,ndim,num_cells,
num_nodes,num_nodes_per_cell, &
Petsc_False,dmplex_cells,ndim, dmplex_verts,dm,ierr)
CHKERRQ(ierr)
else
call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,
0,num_nodes_per_cell, &
Petsc_False,dmplex_cells,ndim,dmplex_verts,dm,ierr)
CHKERRQ(ierr)
end if
if (nprocs > 1) then
call DMSetUseNatural(dm,PETSC_TRUE,ierr)
CHKERRQ(ierr)
end if
call DMPlexDistribute(dm,stencil_width, &
migrationsf,distributedMesh,ierr)
CHKERRQ(ierr)
if (distributedMesh /= PETSC_NULL_DM) then
call PetscSFCreateInverseSF(migrationsf,migrationsf_inv,ierr)
CHKERRQ(ierr)
call
DMCreateGlobalToNatural(distributedMesh,migrationsf,migrationsf_inv,ierr)
CHKERRQ(ierr)
call DMGetSection(distributedMesh,section,ierr)
CHKERRQ(ierr)
call PetscSectionCreate(Petsc_Comm_World,section_seq,ierr)
CHKERRQ(ierr)
call PetscSFDistributeSection(migrationsf_inv,section, &
PETSC_NULL_INTEGER,section_seq,ierr)
CHKERRQ(ierr)
call DMPlexCreateGlobalToNaturalSF(distributedMesh, &
section_seq,migrationsf,sf_natural,ierr)
CHKERRQ(ierr)
call DMSetUseNatural(distributedMesh,PETSC_TRUE,ierr)
CHKERRQ(ierr)
call PetscSFDestroy(migrationsf,ierr)
CHKERRQ(ierr)
call PetscSFDestroy(migrationsf_inv,ierr)
CHKERRQ(ierr)
end if
Danyang
> Thanks,
> Matt
> Regards,
> Danyang
> On 2018-12-03 5:22 a.m., Matthew Knepley wrote:
>> I need to write a custom Fortran stub for this one. I will get it
>> done as soon as possible.
>> Thanks,
>> Matt
>> On Sat, Dec 1, 2018 at 7:16 PM Danyang Su via petsc-users
>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> Hi All,
>> I got a simple compilation error when use
>> PetscSFDistributeSection in
>> Fortran. It looks like the required head files are included
>> and the
>> parameters are correctly defined. However, when compile the
>> code, I got
>> error undefined reference to `petscsfdistributesection_'. The
>> code is
>> shown below. Did I miss anything here?
>> #include <petsc/finclude/petscsys.h>
>> #include <petsc/finclude/petscvec.h>
>> #include <petsc/finclude/petscdm.h>
>> #include <petsc/finclude/petscdmplex.h>
>> use petscsys
>> use petscvec
>> use petscdm
>> use petscdmplex
>> implicit none
>> PetscSection :: section, section_seq
>> PetscSF :: migrationsf_inv, sf_natural
>> Vec :: vec_global, vec_natural
>> PetscErrorCode :: ierr
>> CHKERRQ(ierr)
>> call
>> CHKERRQ(ierr)
>> Thanks,
>> Danyang
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181203/c074fd93/attachment.html>
