[petsc-users] Use block Jacobi preconditioner with SNES
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Aug 28 16:54:04 CDT 2018
Ali,
In the branch barry/feature-PCVPBJACOBI (see src/snes/examples/tutorials/ex5.c) I have implemented PCVPBJACOBI that is a point block Jacobi with variable size blocks. It has very little testing.
Could you please try your code with it; you should see very very similar convergence history with this branch and the previous approach you used (the only numerical difference between the two approaches is that this one uses a dense LU factorization for each small block while the previous used a sparse factorization). This new one should also be slightly faster in the KSPSolve().
Thanks
Barry
> On Aug 27, 2018, at 4:04 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>> I have added new functionality within SNES to allow one to do as you desire in the branch barry/feature-snessetkspsetupcallback. Please see src/snes/examples/tests/ex3.c
> Note that this example is block Jacobi with O(1) sparse blocks per
> process, not variable-sized point-block Jacobi which I think is what Ali
> had in mind.
>> Please let us know if it works for you and if you have any questions or problems.
>> Barry
>> Note that it has to be handled by a callback called from within the SNES solver because that is the first time the matrix exists in a form that the block sizes may be set.
>> Sorry for the runaround with so many emails.
>>> On Aug 24, 2018, at 3:48 PM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> wrote:
>>> Hi,
>>> I am trying to use block Jacobi preconditioner in SNES (SNESNEWTONLS). However, PCBJacobiGetSubKSP function returns an error stating "Object is in wrong state, Must call KSPSetUp() or PCSetUp() first". When I add KSPSetUp, I got and error from them as: "Must call DMShellSetGlobalVector() or DMShellSetCreateGlobalVector()", and if PCSetUp is added, "Object is in wrong state, Matrix must be set first" error is printed.
>>> Below is a part of my code. It is run serially. Any help is much appreciated.
>>> ierr = SNESGetKSP(snes, &Petsc_ksp);
>>> CHKERRQ(ierr);
>>> ierr = KSPGetPC(Petsc_ksp, &Petsc_pc);
>>> CHKERRQ(ierr);
>>> ierr = KSPSetTolerances(Petsc_ksp, 1.e-3, 1e-3, PETSC_DEFAULT, 20000);
>>> CHKERRQ(ierr);
>>> ierr = SNESSetTolerances(snes, 1e-1, 1e-1, 1e-1, 2000, 2000);
>>> CHKERRQ(ierr);
>>> ierr = SNESSetType(snes, SNESNEWTONLS);
>>> CHKERRQ(ierr);
>>> ierr = KSPSetType(Petsc_ksp, KSPGMRES);
>>> CHKERRQ(ierr);
>>> ierr = PCSetType(Petsc_pc, PCBJACOBI);
>>> CHKERRQ(ierr);
>>> CHKERRQ(ierr);
>>> ierr = PCBJacobiSetTotalBlocks(Petsc_pc, 2*Nx*Ny*Nz, SadeqSize);
>>> CHKERRQ(ierr);
>>> SNESSetUp(snes);
>>> CHKERRQ(ierr);
>>> ierr = PCBJacobiGetSubKSP(Petsc_pc, &nLocal, &Firstly, &subKSP);
>>> CHKERRQ(ierr);
>>> for (i = 0; i < nLocal; i++) {
>>> ierr = KSPGetPC(subKSP[i], &SubPc);
>>> CHKERRQ(ierr);
>>> ierr = PCSetType(SubPc, PCLU);
>>> CHKERRQ(ierr);
>>> ierr = PCFactorSetMatSolverPackage(SubPc, "mkl_pardiso");
>>> CHKERRQ(ierr);
>>> ierr = KSPSetType(subKSP[i], KSPPREONLY);
>>> CHKERRQ(ierr);
>>> ierr = KSPSetTolerances(subKSP[i], 1.e-6, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
>>> CHKERRQ(ierr);
>>> ierr = SNESSolve(snes, NULL, Petsc_X);
>>> CHKERRQ(ierr);
>>> Ali Reza Khaz’ali
>>> Assistant Professor of Petroleum Engineering,
>>> Department of Chemical Engineering
>>> Isfahan University of Technology
>>> Isfahan, Iran
