[petsc-users] Use block Jacobi preconditioner with SNES
Jed Brown
jed at jedbrown.org
Mon Aug 27 16:32:43 CDT 2018
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>> I have added new functionality within SNES to allow one to do as you desire in the branch barry/feature-snessetkspsetupcallback. Please see src/snes/examples/tests/ex3.c
>> Note that this example is block Jacobi with O(1) sparse blocks per
>> process, not variable-sized point-block Jacobi which I think is what Ali
>> had in mind.
> It is almost a cut and paste of the original code provided, just
> set up as a callback.
Yeah, but each of these blocks would be less than 10x10.
PCBJacobiSetTotalBlocks(Petsc_pc, 2*Nx*Ny*Nz, SadeqSize);
> If it performs well convergence wise then
Yes.
> one could consider implementing the (presumably) more efficient
> variable blocksize point block Jacobi (either as an entirely new
> preconditioner or as an option to the current point block Jacobi;
> I would advocate a new one PCVPBJACOBI in order to limit code
> complexity even though there might be a bit of code duplication.)
Yeah, possibly. We'd need MatInvertBlockDiagonal (or a generalization)
to be able to return a variable block size at which point it's almost
the same.
