[petsc-users] Use block Jacobi preconditioner with SNES
Jed Brown jed at jedbrown.org
Mon Aug 27 14:36:57 CDT 2018
Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> writes:
>> The BAIJ blocks are usually grouping of fields for each discretization
>> "point".  NEST is usually grouping different fields with which you want
>> to use different sparse solution strategies (e.g., algebraic multigrid
>> on some, a simpler solver on others).
> I have to apologize for taking so much of your time. I'd be grateful if
> you could kindly answer my (hopefully last) question: what do you
> propose for a non-linear system that has variable number of unknowns in
> each of its discretization points?
Normal AIJ.
