[petsc-users] Use block Jacobi preconditioner with SNES
Ali Reza Khaz'ali
arkhazali at cc.iut.ac.ir
Mon Aug 27 14:31:05 CDT 2018
> The BAIJ blocks are usually grouping of fields for each discretization
> "point". NEST is usually grouping different fields with which you want
> to use different sparse solution strategies (e.g., algebraic multigrid
> on some, a simpler solver on others).
I have to apologize for taking so much of your time. I'd be grateful if
you could kindly answer my (hopefully last) question: what do you
propose for a non-linear system that has variable number of unknowns in
each of its discretization points?
Many thanks,
Ali
