[petsc-users] LINEAR SOLVER
Fri Aug 24 06:59:45 CDT 2018
On Fri, Aug 24, 2018 at 5:48 AM Savneet Kaur <Savneet.KAUR at cea.fr> wrote:
> Hello,
> I am having a small trouble with PETSC.
> I am trying to use linear solver methods: LU and CHOLESKY but unable to
> run the code. The error message which I am getting is  "See
> http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html for
> possible LU and Cholesky solvers
> [0]PETSC ERROR: Could not locate a solver package. Perhaps you must
> ./configure with --download-<package>
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting."
> Please do not truncate the error message. Send all output.
In order to use some other package, like MUMPS, you need
  *-pc_factor_mat_solver_type mumps*
> But while installing the PETSC, I am using this command line for the
> configuration *"./configure --with-cc=mpicc --with-fc=mpif90
> --with-cxx=mpicxx --download-scalapack --download-mumps --download-hypre
> --download-parmetis --download-metis" .. *which should eventually install
> LU and cholesky packages as i am calling them to configure it using MUMPS
> package.
> And my second question would be, I want to install the non debug version
> of the PETSC and SLEPC. If you can help me in that?
> Infact, I even tried configruing with *"--with-debugging=0". *But it did
> not changed anything.
> Perhaps you misspelled it. Please send configure.log for this build.
     Matt
> Looking forward for your response.
> Thanks in advance.
> Regards,
> Savneet kaur
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180824/2682392b/attachment-0001.html>
