[petsc-users] MatSetValues error with ViennaCL types
Manuel Valera
mvalera-w at sdsu.edu
Wed Aug 15 16:20:26 CDT 2018
It seems to be resumed on: I do not know how to preallocate a DM Matrix
correctly.
The interesting part is that it only breaks when i need to populate a GPU
matrix from MPI, so kudos on that, but it seems i need to do better on my
code to get this setup working,
Any help would be appreciated,
On Wed, Aug 15, 2018 at 2:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 15, 2018 at 4:53 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> Thanks Matthew,
>> I try to do that when calling:
>> call MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,PETSC_
>> NULL_INTEGER,ierr)
>> But i am not aware on how to do this for the DM if it needs something
>> more specific/different,
> The error says that your preallocation is wrong for the values you are
> putting in. The DM does not control either,
> so I do not understand your email.
> Thanks,
> Matt
>> Thanks,
>> On Wed, Aug 15, 2018 at 1:51 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Aug 15, 2018 at 4:39 PM Manuel Valera <mvalera-w at sdsu.edu>
>>> wrote:
>>>> Hello PETSc devs,
>>>> I am running into an error when trying to use the MATMPIAIJVIENNACL
>>>> Matrix type in MPI calls, the same code runs for MATSEQAIJVIENNACL type in
>>>> one processor. The error happens when calling MatSetValues for this
>>>> specific configuration. It does not occur when using MPI DMMatrix types
>>>> only.
>>> The DM properly preallocates the matrix. I am assuming you do not here.
>>> Matt
>>>> Any help will be appreciated,
>>>> Thanks,
>>>> My program call:
>>>> mpirun -n 2 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>>>> jid=tiny_cuda_test_n2 -ksp_type cg -dm_vec_type viennacl -dm_mat_type
>>>> aijviennacl -pc_type saviennacl -log_view
>>>> The error (repeats after each MatSetValues call):
>>>> [1]PETSC ERROR: --------------------- Error Message
>>>> [1]PETSC ERROR: Argument out of range
>>>> [1]PETSC ERROR: Inserting a new nonzero at global row/column (75, 50)
>>>> into matrix
>>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [1]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53
>>>> GIT Date: 2018-05-31 17:31:13 +0300
>>>> [1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed
>>>> Aug 15 13:10:44 2018
>>>> [1]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
>>>> --with-mpi-dir=/usr/lib64/openmpi --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
>>>> --FOPTFLAGS=-O2 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>>> --CUDAFLAGS=-arch=sm_60 --with-blaslapack-dir=/usr/lib64
>>>> --download-viennacl
>>>> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 608 in
>>>> /home/valera/petsc/src/mat/impls/aij/mpi/mpiaij.c
>>>> [1]PETSC ERROR: #2 MatSetValues() line 1339 in
>>>> /home/valera/petsc/src/mat/interface/matrix.c
>>>> My Code structure:
>>>> call DMCreateMatrix(daDummy,A,ierr)
>>>>> call MatSetFromOptions(A,ierr)
>>>>> call MPI_Comm_size(PETSC_COMM_WORLD, numprocs, ierr)
>>>>> if (numprocs > 1) then ! set matrix type parallel
>>>>> ! Get local size
>>>>> call DMDACreateNaturalVector(daDummy,Tmpnat,ierr)
>>>>> call VecGetLocalSize(Tmpnat,locsize,ierr)
>>>>> call VecDestroy(Tmpnat,ierr)
>>>>> ! Set matrix
>>>>> #ifdef GPU
>>>>> call MatSetType(A,MATAIJVIENNACL,ierr)
>>>>> call DMSetMatType(daDummy,MATMPIAIJVIENNACL,ierr)
>>>>> call DMSetVecType(daDummy,VECMPIVIENNACL,ierr)
>>>>> print*,'SETTING GPU TYPES'
>>>>> #else
>>>>> call DMSetMatType(daDummy,MATMPIAIJ,ierr)
>>>>> call DMSetMatType(daDummy,VECMPI,ierr)
>>>>> call MatSetType(A,MATMPIAIJ,ierr)!
>>>>> #endif
>>>>> PETSC_NULL_INTEGER,ierr)
>>>>> else ! set matrix type sequential
>>>>> #ifdef GPU
>>>>> call DMSetMatType(daDummy,MATSEQAIJVIENNACL,ierr)
>>>>> call DMSetVecType(daDummy,VECSEQVIENNACL,ierr)
>>>>> call MatSetType(A,MATSEQAIJVIENNACL,ierr)
>>>>> #else
>>>>> call DMSetMatType(daDummy,MATSEQAIJ,ierr)
>>>>> call DMSetMatType(daDummy,VECSEQ,ierr)
>>>>> call MatSetType(A,MATSEQAIJ,ierr)
>>>>> #endif
>>>>> call MatSetUp(A,ierr)
>>>>> call getCenterInfo(daGrid,xstart,ystart,zstart,xend,yend,zend)
>>>>> do k=zstart,zend-1
>>>>> do j=ystart,yend-1
>>>>> do i=xstart,xend-1
>>>>> call MatSetValues(A,1,row,sumpos,
>>>>> pos(0:iter-1),vals(0:iter-1),INSERT_VALUES,ierr)
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180815/0cdb9386/attachment.html>
