[petsc-users] MatSetValues error with ViennaCL types
Matthew Knepley
knepley at gmail.com
Wed Aug 15 16:15:02 CDT 2018
On Wed, Aug 15, 2018 at 4:53 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
> Thanks Matthew,
> I try to do that when calling:
> call MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,
> PETSC_NULL_INTEGER,ierr)
> But i am not aware on how to do this for the DM if it needs something more
> specific/different,
The error says that your preallocation is wrong for the values you are
putting in. The DM does not control either,
so I do not understand your email.
Matt
> Thanks,
> On Wed, Aug 15, 2018 at 1:51 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Aug 15, 2018 at 4:39 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
>>> Hello PETSc devs,
>>> I am running into an error when trying to use the MATMPIAIJVIENNACL
>>> Matrix type in MPI calls, the same code runs for MATSEQAIJVIENNACL type in
>>> one processor. The error happens when calling MatSetValues for this
>>> specific configuration. It does not occur when using MPI DMMatrix types
>>> only.
>> The DM properly preallocates the matrix. I am assuming you do not here.
>> Matt
>>> Any help will be appreciated,
>>> Thanks,
>>> My program call:
>>> mpirun -n 2 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>>> jid=tiny_cuda_test_n2 -ksp_type cg -dm_vec_type viennacl -dm_mat_type
>>> aijviennacl -pc_type saviennacl -log_view
>>> The error (repeats after each MatSetValues call):
>>> [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR: Argument out of range
>>> [1]PETSC ERROR: Inserting a new nonzero at global row/column (75, 50)
>>> into matrix
>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [1]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53 GIT
>>> Date: 2018-05-31 17:31:13 +0300
>>> [1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed
>>> Aug 15 13:10:44 2018
>>> [1]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
>>> --with-mpi-dir=/usr/lib64/openmpi --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
>>> --FOPTFLAGS=-O2 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>> --CUDAFLAGS=-arch=sm_60 --with-blaslapack-dir=/usr/lib64 --download-viennacl
>>> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 608 in
>>> /home/valera/petsc/src/mat/impls/aij/mpi/mpiaij.c
>>> [1]PETSC ERROR: #2 MatSetValues() line 1339 in
>>> /home/valera/petsc/src/mat/interface/matrix.c
>>> My Code structure:
>>> call DMCreateMatrix(daDummy,A,ierr)
>>>> call MatSetFromOptions(A,ierr)
>>>> call MPI_Comm_size(PETSC_COMM_WORLD, numprocs, ierr)
>>>> if (numprocs > 1) then ! set matrix type parallel
>>>> ! Get local size
>>>> call DMDACreateNaturalVector(daDummy,Tmpnat,ierr)
>>>> call VecGetLocalSize(Tmpnat,locsize,ierr)
>>>> call VecDestroy(Tmpnat,ierr)
>>>> ! Set matrix
>>>> #ifdef GPU
>>>> call MatSetType(A,MATAIJVIENNACL,ierr)
>>>> call DMSetMatType(daDummy,MATMPIAIJVIENNACL,ierr)
>>>> call DMSetVecType(daDummy,VECMPIVIENNACL,ierr)
>>>> print*,'SETTING GPU TYPES'
>>>> #else
>>>> call DMSetMatType(daDummy,MATMPIAIJ,ierr)
>>>> call DMSetMatType(daDummy,VECMPI,ierr)
>>>> call MatSetType(A,MATMPIAIJ,ierr)!
>>>> #endif
>>>> call
>>>> MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,PETSC_NULL_INTEGER,ierr)
>>>> else ! set matrix type sequential
>>>> #ifdef GPU
>>>> call DMSetMatType(daDummy,MATSEQAIJVIENNACL,ierr)
>>>> call DMSetVecType(daDummy,VECSEQVIENNACL,ierr)
>>>> call MatSetType(A,MATSEQAIJVIENNACL,ierr)
>>>> #else
>>>> call DMSetMatType(daDummy,MATSEQAIJ,ierr)
>>>> call DMSetMatType(daDummy,VECSEQ,ierr)
>>>> call MatSetType(A,MATSEQAIJ,ierr)
>>>> #endif
>>>> call MatSetUp(A,ierr)
>>>> call getCenterInfo(daGrid,xstart,ystart,zstart,xend,yend,zend)
>>>> do k=zstart,zend-1
>>>> do j=ystart,yend-1
>>>> do i=xstart,xend-1
>>>> call
>>>> MatSetValues(A,1,row,sumpos,pos(0:iter-1),vals(0:iter-1),INSERT_VALUES,ierr)
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180815/0a2a1b9a/attachment-0001.html>
