[petsc-users] SLEPc - Davidson-type solvers options
Michael Werner michael.werner at dlr.de
Mon Aug 6 07:44:56 CDT 2018
Michael Werner writes:
> Hello, I want to use a Davidson-type solver (probably jd) to
> find
> the eigenvalues with the smallest real part, but so far I'm
> strugglung to get them to converge. So I was hoping to get some
> advice on the various  options available for those solvers.
> For my test case, I know the smallest eigenvalue is -0.04+0.71i
> (calculated with shift-and-invert and lu
> preconditioner). However,
> when I try to use jd or gd, the eigensolver never
> converges. After
> a few iterations, the "first unconverged value" is more or less
> as
> expected, but it fluctuates around the correct value, and the
> residual never drops below 1e-2. The best results so far were
> achieved with the following set of commandline options:
> -st_type precond -st_pc_type asm -st_sub_pc_type ilu
>  -st_sub_pc_factor_levels 2 -st_ksp_max_it 15 -st_ksp_rtol 1e-2
>  -eps_type jd -eps_tol 1e-4 -eps_monitor -eps_nev 5 -eps_target
>  -0.08 -eps_target_real -eps_harmonic_largest
> I also tried using more ksp iterations or different
> st_sub_pc_factor_levels. I also tried using eps_smallest_real
> instead of a target value, without any success. So far, I
> noticed
> that the extraction type had the largest influence. Only for
> eps_harmonic_largest could I observe any eigenvalues with
> negative
> real part, for all the other extraction types I only got
> eigenvalues with positive real parts.
> I also had a look at the available options for the Davidson
> solvers, but I couldn't find a good explanation for
Sorry, I didn't mean to send it already. What I wanted to say:
solvers, but I couldn't find a good explanation for many of the
additional options. Is there any recommendation to chose -eps_mpd
or -eps_jd_minv? And can -eps_jd_plusk be used for GNHEP-type
problems? I already had a look at the paper of E. Romero and
J. E. Roman concerning the implementation of the Davidson-type
solvers in SLEPc, but it didn't answer all my questions.
Kind regards,
Michael
