[petsc-users] SLEPc - Davidson-type solvers options
Michael Werner michael.werner at dlr.de
Mon Aug 6 07:38:14 CDT 2018
Hello, I want to use a Davidson-type solver (probably jd) to find
the eigenvalues with the smallest real part, but so far I'm
strugglung to get them to converge. So I was hoping to get some
advice on the various  options available for those solvers.
For my test case, I know the smallest eigenvalue is -0.04+0.71i
(calculated with shift-and-invert and lu preconditioner). However,
when I try to use jd or gd, the eigensolver never converges. After
a few iterations, the "first unconverged value" is more or less as
expected, but it fluctuates around the correct value, and the
residual never drops below 1e-2. The best results so far were
achieved with the following set of commandline options:
-st_type precond -st_pc_type asm -st_sub_pc_type ilu
 -st_sub_pc_factor_levels 2 -st_ksp_max_it 15 -st_ksp_rtol 1e-2
 -eps_type jd -eps_tol 1e-4 -eps_monitor -eps_nev 5 -eps_target
 -0.08 -eps_target_real -eps_harmonic_largest
I also tried using more ksp iterations or different
st_sub_pc_factor_levels. I also tried using eps_smallest_real
instead of a target value, without any success. So far, I noticed
that the extraction type had the largest influence. Only for
eps_harmonic_largest could I observe any eigenvalues with negative
real part, for all the other extraction types I only got
eigenvalues with positive real parts.
I also had a look at the available options for the Davidson
solvers, but I couldn't find a good explanation for
____________________________________________________
Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 |
37073 Göttingen
Michael Werner
Telefon 0551 709-2627 | Telefax 0551 709-2811 |
Michael.Werner at dlr.de
DLR.de
