[petsc-users] Get vertex index of each cell in DMPlex after distribution
Fri Apr 27 06:11:19 CDT 2018
On Fri, Apr 27, 2018 at 2:09 AM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi Matt,
> Sorry if this is a stupid question.
> In the previous code for unstructured grid, I create labels to mark the
> original node/cell index from VTK file and then distribute it so that each
> subdomain has a copy of its original node and cell index, as well as the
> PETSc numbering. Now I am trying to get avoid of using large number of keys
> in DMSetLabelValue since this costs lot of time for large problem.
> I can get the coordinates of subdomain after distribution by using
> DMGetCoordinatesLocal and DMGetCoordinateDM.
> How can I get the vertex index of each cell after distribution? Would you
> please give me a hint or functions that I can use.
You can permute the vectors back to the natural ordering using
http://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexNaturalToGlobalBegin.html
which says you have to call DMPlexSetUseNaturalSF() before distributing the
mesh. It is tested in
  src/dm/impls/plex/examples/tests/ex15.c
so you can see how its intended to work. It is very new and has not been
tested by many people.
I can see how you might want this for small tests. Why would you want it
for production models?
    Matt
> Thanks,
> Danyang
> On 18-04-25 02:12 PM, Danyang Su wrote:
> On 2018-04-25 09:47 AM, Matthew Knepley wrote:
> On Wed, Apr 25, 2018 at 12:40 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi Matthew,
>> In the worst case, every node/cell may have different label.
> Do not use Label for this. Its not an appropriate thing. If every cell is
> different, just use the cell number.
> Labels are for mapping a relatively small number of keys (like material
> IDs) to sets of points (cells, vertices, etc.)
> Its not a great data structure for a permutation.
> Yes. If there is small number of keys, it runs very fast, even for more
> than one million DMSetLabelValue calls. The performance just deteriorates
> as the number of keys increases.
> I cannot get avoid of DMSetLabelValue as node/cell index of original mesh
> is needed for the previous input file that uses some of global node/cell
> index to set value. But if I can get the natural order of nodes/cells from
> DMPlex, I can discard the use of DMSetLabelValue. Is there any function can
> do this job?
> Thanks,
> Danyang
> However, I still do not believe these numbers. The old code does a string
> comparison every time. I will setup a test.
>    Matt
>> Below is one of the worst scenario with 102299 nodes and 102299 different
>> labels for test. I found the time cost increase during the loop. The first
>> 9300 loop takes least time (<0.5) while the last 9300 loops takes much more
>> time (>7.7), as shown below. If I use larger mesh with >1 million nodes, it
>> runs very very slowly in this part. The PETSc is configured with
>> optimization on.
>> Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
>> --download-mpich --download-scalapack --download-parmetis --download-metis
>> --download-ptscotch --download-fblaslapack --download-hypre
>> --download-superlu_dist --download-hdf5=yes --download-ctetgen
>> --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
>> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native
>> -mtune=native"
>> istart iend progress CPU_Time time cost - old (sec) time cost - new (sec)
>> 0 9299 0 1524670045.51166
>> 9300 18599 0.100010753 1524670045.99605 0.4843890667 0.497246027
>> 18600 27899 0.200010747 1524670047.32635 1.330302 1.3820912838
>> 27900 37199 0.300010741 1524670049.3066 1.9802515507 2.2439446449
>> 37200 46499 0.400010765 1524670052.1594 2.852804184 3.0739262104
>> 46500 55799 0.500010729 1524670055.90961 3.7502081394 3.9270553589
>> 55800 65099 0.600010753 1524670060.47654 4.5669286251 4.7571902275
>> 65100 74399 0.700010777 1524670066.0941 5.6175630093 5.7428796291
>> 74400 83699 0.800010741 1524670072.53886 6.44475317 6.5761549473
>> 83700 92998 0.900010765 1524670079.99072 7.4518604279 7.4606924057
>> 92999 102298 1 1524670087.71066 7.7199423313 8.2424075603
>> old code
>>         do ipoint = 0, istart-1
>>           !c output time cost, use 1 processor to test
>>           if (b_enable_output .and. rank == 0) then
>>             if (mod(ipoint,iprogress) == 0 .or. ipoint == istart-1) then
>>               !write(*,'(f3.1,1x)',advance="no") (ipoint+1.0)/istart
>>               write(*,*) ipoint, (ipoint+1.0)/istart,"time",MPI_Wtime()
>>             end if
>>           end if
>>           call DMSetLabelValue(dmda_flow%da,"cid_lg2g",ipoint,         &
>>                                ipoint+1,ierr)
>>           CHKERRQ(ierr)
>>         end do
>> new code
>>         call DMCreateLabel(dmda_flow%da,'cid_lg2g',ierr)
>>         CHKERRQ(ierr)
>>         call DMGetLabel(dmda_flow%da,'cid_lg2g',label, ierr)
>>         CHKERRQ(ierr)
>>             end if
>>           end if
>>           call DMLabelSetValue(label,ipoint,ipoint+1,ierr)
>>           CHKERRQ(ierr)
>>         end do
>> Thanks,
>> Danyang
>> On 2018-04-25 03:16 AM, Matthew Knepley wrote:
>> On Tue, Apr 24, 2018 at 11:57 PM, Danyang Su <danyang.su at gmail.com>
>> wrote:
>>> Hi All,
>>> I use DMPlex in unstructured grid code and recently found
>>> DMSetLabelValue takes a lot of time for large problem, e.g., num. of cells
>>> > 1 million. In my code, I use
>> I read your code wrong. For large loop, you should not use the
>> convenience function. You should use
>>> DMPlexCreateFromCellList ()
>> DMGetLabel(dm, name, &label)
>>> Loop over all cells/nodes{
>>> DMSetLabelValue
>> Replace this by DMLabelSetValue(label, point, val)
>>> DMPlexDistribute
>>> The code works fine except DMSetLabelValue takes a lot of time for large
>>> problem. I use DMSetLabelValue to set material id for all the nodes or
>>> cells so that each subdomain has a copy of material id. Is there any other
>>> functions that can be used more efficient, e.g. set labels by array, not 1
>>> by 1?
>> That should take much less time.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Danyang
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180427/00aabfee/attachment-0001.html>
