[petsc-users] configuration option for PETSc on cluster
    Randall Mackie
    rlmackie862 at gmail.com
    Tue Apr 24 12:19:34 CDT 2018
I haven’t followed this thread completely, but have you sourced the Intel mklvars.sh file?
I do the following, for example,
source …/intel_2018/mkl/bin/mklvars.sh intel64
Then in our configure it’s simply:
—with-blas-lapack-dir=…/intel_2018/mkl
and this works fine and picks up all the right Intel libraries.
It could be set up differently on your system though.
Randy M.
> On Apr 24, 2018, at 9:23 AM, Samuel Lanthaler <s.lanthaler at gmail.com> wrote:
> Dear Satish,
> As you suggested, the configure appears to work with
> ./configure --with-fc=ftn --with-cc=cc --with-cxx=CC --with-debugging=0 --with-scalar-type=complex --download-scalapack --download-mumps=yes --download-superlu --with-batch --known-mpi-shared-libraries=1 --with-blaslapack-dir=${MKLROOT} --known-64-bit-blas-indices=0 --LDFLAGS="-dynamic"
> However, after doing the reconfigure, I tried to compile using make, and ran into trouble with CLINKER:
>            CC arch-complex/obj/sys/classes/draw/impls/x/xops.o
>     CLINKER arch-complex/lib/libpetsc.so.3.09.0
> Warning:
> -dynamic was already seen on command line, overriding with -shared.
> /usr/bin/ld: arch-complex/obj/sys/fsrc/somefort.o: relocation R_X86_64_32 against `petscfortran5_' can not be used when making a shared object; recompile with -fPIC
> arch-complex/obj/sys/fsrc/somefort.o: error adding symbols: Bad value
> **************************ERROR*************************************
>  Error during compile, check arch-complex/lib/petsc/conf/make.log
>  Send it and arch-complex/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov
> makefile:30: recipe for target 'all' failed
> make: *** [all] Error 1
> Any ideas? Again, I'm attaching the .log files.
> On 04/24/2018 04:14 PM, Satish Balay wrote:
>> Sorry I should have clarified - its a configure option.
>> Satish
>> On Tue, 24 Apr 2018, Samuel Lanthaler wrote:
>>> Sorry, I'm confused: Can I add this somehow when doing the ./configure? Or do
>>> you mean to add it when compiling ex5f with the configuration I had initially?
>>> Cheers,
>>> Samuel
>>> On 04/24/2018 04:03 PM, Satish Balay wrote:
>>>> Ok - I do see: libmkl_intel_lp64.so libmkl_sequential.so libmkl_core.so -
>>>> these should
>>>> be the ones that get picked up.
>>>> I do not know why 'cc' is picking up static libraries instead of the
>>>> shared ones. Perhaps it needs an extra option
>>>> 'LDFLAGS=-dynamic'
>>>> Satish
>>>>> Dear Satish,
>>>>> I get the following when doing the ls:
>>>>> [lanthale at daint103 mkl]$ ls
>>>>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/
>>>>> libmkl_ao_worker.so             libmkl_blacs_sgimpt_lp64.so
>>>>> libmkl_intel_lp64.a        libmkl_sequential.so
>>>>> libmkl_avx2.so                  libmkl_blas95_ilp64.a libmkl_intel_lp64.so
>>>>> libmkl_tbb_thread.a
>>>>> libmkl_avx512_mic.so            libmkl_blas95_lp64.a libmkl_intel_thread.a
>>>>> libmkl_tbb_thread.so
>>>>> libmkl_avx512.so                libmkl_cdft_core.a libmkl_intel_thread.so
>>>>> libmkl_vml_avx2.so
>>>>> libmkl_avx.so                   libmkl_cdft_core.so libmkl_lapack95_ilp64.a
>>>>> libmkl_vml_avx512_mic.so
>>>>> libmkl_blacs_intelmpi_ilp64.a   libmkl_core.a libmkl_lapack95_lp64.a
>>>>> libmkl_vml_avx512.so
>>>>> libmkl_blacs_intelmpi_ilp64.so  libmkl_core.so libmkl_mc3.so
>>>>> libmkl_vml_avx.so
>>>>> libmkl_blacs_intelmpi_lp64.a    libmkl_def.so libmkl_mc.so
>>>>> libmkl_vml_cmpt.so
>>>>> libmkl_blacs_intelmpi_lp64.so   libmkl_gf_ilp64.a libmkl_pgi_thread.a
>>>>> libmkl_vml_def.so
>>>>> libmkl_blacs_openmpi_ilp64.a    libmkl_gf_ilp64.so libmkl_pgi_thread.so
>>>>> libmkl_vml_mc2.so
>>>>> libmkl_blacs_openmpi_ilp64.so   libmkl_gf_lp64.a libmkl_rt.so
>>>>> libmkl_vml_mc3.so
>>>>> libmkl_blacs_openmpi_lp64.a     libmkl_gf_lp64.so libmkl_scalapack_ilp64.a
>>>>> libmkl_vml_mc.so
>>>>> libmkl_blacs_openmpi_lp64.so    libmkl_gnu_thread.a
>>>>> libmkl_scalapack_ilp64.so
>>>>> locale
>>>>> libmkl_blacs_sgimpt_ilp64.a     libmkl_gnu_thread.so
>>>>> libmkl_scalapack_lp64.a
>>>>> libmkl_blacs_sgimpt_ilp64.so    libmkl_intel_ilp64.a
>>>>> libmkl_scalapack_lp64.so
>>>>> libmkl_blacs_sgimpt_lp64.a      libmkl_intel_ilp64.so libmkl_sequential.a
>>>>> Cheers,
>>>>> Samuel
>>>>> On 04/24/2018 03:50 PM, Satish Balay wrote:
>>>>>> Executing: cc  -o /tmp/petsc-tyd_Hm/config.libraries/conftest     -O
>>>>>> /tmp/petsc-tyd_Hm/config.libraries/conftest.o
>>>>>> -Wl,-rpath,/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64
>>>>>> -L/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64
>>>>>> -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lstdc++ -ldl
>>>>>> Possible ERROR while running linker: exit code 256
>>>>>> stderr:
>>>>>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(mkl_semaphore.o):
>>>>>> In function `mkl_serv_load_inspector':
>>>>>> mkl_semaphore.c:(.text+0x123): warning: Using 'dlopen' in statically
>>>>>> linked
>>>>>> applications requires at runtime the shared libraries from the glibc
>>>>>> version
>>>>>> used for linking
>>>>>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(dgetrs.o):
>>>>>> In function `mkl_lapack_dgetrs':
>>>>>> dgetrs_gen.f:(.text+0x224): undefined reference to `mkl_blas_dtrsm'
>>>>>> dgetrs_gen.f:(.text+0x2b1): undefined reference to `mkl_blas_dtrsm'
>>>>>> dgetrs_gen.f:(.text+0x2e7): undefined reference to `mkl_lapack_dlaswp'
>>>>>> For some reason the compiler is picking up static version of MKL - instead
>>>>>> of shared libraries.
>>>>>> What do you have for:
>>>>>> ls /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/
>>>>>> Satish
>>>>>>> Dear Satish and Stefano,
>>>>>>> Thank you for your answers. I believe I had initially tried to use the
>>>>>>> option
>>>>>>> --with-blaslapack-dir=[...], instead of specifying lib and include
>>>>>>> directly.
>>>>>>> But that gives me an error message:
>>>>>>>            UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>>>>>> for
>>>>>>> details):
>>>>>>> You set a value for --with-blaslapack-dir=<dir>, but
>>>>>>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl cannot be used
>>>>>>> I attach the new configure.log. Do you think there is something wrong
>>>>>>> with
>>>>>>> the
>>>>>>> mkl version that I'm trying to use? Or is it only related to petsc?
>>>>>>> Cheers,
>>>>>>> Samuel
>>>>>>>>> Hi there,
>>>>>>>>> I was wondering if you could help me with the correct configuration of
>>>>>>>>> PETSc-dev version on a cluster (https://www.cscs.ch/)? I'm not sure
>>>>>>>>> which
>>>>>>>>> information would be useful to you, but basically the problem seems to
>>>>>>>>> be
>>>>>>>>> in
>>>>>>>>> correctly compiling it with intel compiler and the existing mkl
>>>>>>>>> library.
>>>>>>>>> The pre-installed mkl version is
>>>>>>>>> intel/17.0.4.196
>>>>>>>>> I have tried various things and finally, I got it at least to compile
>>>>>>>>> with
>>>>>>>>> the
>>>>>>>>> following options (options chosen in reference to the mkl link
>>>>>>>>> advisor...):
>>>>>>>>> *--with-blaslapack-lib=*" ${MKLROOT}/lib/intel64/libmkl_blas95_lp64.a
>>>>>>>>> ${MKLROOT}/lib/intel64/libmkl_lapack95_lp64.a -Wl,--start-group
>>>>>>>>> ${MKLROOT}/lib/intel64/libmkl_intel_lp64.a
>>>>>>>>> ${MKLROOT}/lib/intel64/libmkl_sequential.a
>>>>>>>>> ${MKLROOT}/lib/intel64/libmkl_core.a -Wl,--end-group -lpthread -lm
>>>>>>>>> -ldl"
>>>>>>>>> *--with-blaslapack-include*="[/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include,/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include/intel64/lp64]"
>>>>>>>> Can you remove the above 2 options [--with-blaslapack-lib,
>>>>>>>> --with-blaslapack-include] and use:
>>>>>>>> --with-blas-lapack-dir=${MKLROOT}
>>>>>>>> And see if you still have this problem?
>>>>>>>> Satish
>>>>>>>>> After compilation, when trying to compile
>>>>>>>>> /users/lanthale/petsc-git/src/snes/examples/tutorials/ex5f I get
>>>>>>>>> linking
>>>>>>>>> errors (attached). Would anyone be able to help me out here? I really
>>>>>>>>> don't
>>>>>>>>> have a good understanding of this.
>>>>>>>>> I'm attaching the configuration.log file, as well as the linking errors
>>>>>>>>> when
>>>>>>>>> trying to compile ex5f.
>>>>>>>>> Thank you very much in advance!
>>>>>>>>> Best regards,
>>>>>>>>> Samuel
> <make.log><configure.log>
