[petsc-users] configuration option for PETSc on cluster
Samuel Lanthaler s.lanthaler at gmail.com
Tue Apr 24 09:15:01 CDT 2018
... wait a minute, I found this on the cluster website
    Regardless of which programming environment (compiler suite) you are
    using, you should always compile code with the Cray wrapper commands
    (|cc| for C code, |CC| for C++ code and |ftn| for Fortran code).
    _The compiler wrappers produce statically-linked executables by
    default; for dynamic libraries use the __|-dynamic|__flag or
    __|export CRAYPE_LINK_TYPE=dynamic|__before building._ Note that
    dynamic linking is the default when the cudatoolkit module is
    loaded. You should include the compiler flags appropriate to the
    underlying compiler suite (Intel, GNU, PGI, Cray). There are also
    specific options for the
    wrappers themselves: see the man pages of |ftn|, |cc|, and |CC| for
    details
|| That sounds like what you were saying Satish. I'll try again with
"|export CRAYPE_LINK_TYPE=dynamic"| and come back to you! Thanks.
On 04/24/2018 04:03 PM, Satish Balay wrote:
> Ok - I do see: libmkl_intel_lp64.so libmkl_sequential.so libmkl_core.so - these should
> be the ones that get picked up.
> I do not know why 'cc' is picking up static libraries instead of the
> shared ones. Perhaps it needs an extra option
> 'LDFLAGS=-dynamic'
> Satish
> On Tue, 24 Apr 2018, Samuel Lanthaler wrote:
>> Dear Satish,
>> I get the following when doing the ls:
>> [lanthale at daint103 mkl]$ ls
>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/
>> libmkl_ao_worker.so             libmkl_blacs_sgimpt_lp64.so
>> libmkl_intel_lp64.a        libmkl_sequential.so
>> libmkl_avx2.so                  libmkl_blas95_ilp64.a libmkl_intel_lp64.so
>> libmkl_tbb_thread.a
>> libmkl_avx512_mic.so            libmkl_blas95_lp64.a libmkl_intel_thread.a
>> libmkl_tbb_thread.so
>> libmkl_avx512.so                libmkl_cdft_core.a libmkl_intel_thread.so
>> libmkl_vml_avx2.so
>> libmkl_avx.so                   libmkl_cdft_core.so libmkl_lapack95_ilp64.a
>> libmkl_vml_avx512_mic.so
>> libmkl_blacs_intelmpi_ilp64.a   libmkl_core.a libmkl_lapack95_lp64.a
>> libmkl_vml_avx512.so
>> libmkl_blacs_intelmpi_ilp64.so  libmkl_core.so libmkl_mc3.so
>> libmkl_vml_avx.so
>> libmkl_blacs_intelmpi_lp64.a    libmkl_def.so libmkl_mc.so
>> libmkl_vml_cmpt.so
>> libmkl_blacs_intelmpi_lp64.so   libmkl_gf_ilp64.a libmkl_pgi_thread.a
>> libmkl_vml_def.so
>> libmkl_blacs_openmpi_ilp64.a    libmkl_gf_ilp64.so libmkl_pgi_thread.so
>> libmkl_vml_mc2.so
>> libmkl_blacs_openmpi_ilp64.so   libmkl_gf_lp64.a libmkl_rt.so
>> libmkl_vml_mc3.so
>> libmkl_blacs_openmpi_lp64.a     libmkl_gf_lp64.so libmkl_scalapack_ilp64.a
>> libmkl_vml_mc.so
>> libmkl_blacs_openmpi_lp64.so    libmkl_gnu_thread.a libmkl_scalapack_ilp64.so
>> locale
>> libmkl_blacs_sgimpt_ilp64.a     libmkl_gnu_thread.so libmkl_scalapack_lp64.a
>> libmkl_blacs_sgimpt_ilp64.so    libmkl_intel_ilp64.a libmkl_scalapack_lp64.so
>> libmkl_blacs_sgimpt_lp64.a      libmkl_intel_ilp64.so libmkl_sequential.a
>> Cheers,
>> Samuel
>> On 04/24/2018 03:50 PM, Satish Balay wrote:
>>> Executing: cc  -o /tmp/petsc-tyd_Hm/config.libraries/conftest     -O
>>> /tmp/petsc-tyd_Hm/config.libraries/conftest.o
>>> -Wl,-rpath,/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64
>>> -L/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64
>>> -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lstdc++ -ldl
>>> Possible ERROR while running linker: exit code 256
>>> stderr:
>>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(mkl_semaphore.o):
>>> In function `mkl_serv_load_inspector':
>>> mkl_semaphore.c:(.text+0x123): warning: Using 'dlopen' in statically linked
>>> applications requires at runtime the shared libraries from the glibc version
>>> used for linking
>>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(dgetrs.o):
>>> In function `mkl_lapack_dgetrs':
>>> dgetrs_gen.f:(.text+0x224): undefined reference to `mkl_blas_dtrsm'
>>> dgetrs_gen.f:(.text+0x2b1): undefined reference to `mkl_blas_dtrsm'
>>> dgetrs_gen.f:(.text+0x2e7): undefined reference to `mkl_lapack_dlaswp'
>>> For some reason the compiler is picking up static version of MKL - instead
>>> of shared libraries.
>>> What do you have for:
>>> ls /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/
>>> Satish
>>>> Dear Satish and Stefano,
>>>> Thank you for your answers. I believe I had initially tried to use the
>>>> option
>>>> --with-blaslapack-dir=[...], instead of specifying lib and include
>>>> directly.
>>>> But that gives me an error message:
>>>>            UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>>>> details):
>>>> You set a value for --with-blaslapack-dir=<dir>, but
>>>> /opt/intel/compilers_and_libraries_2017.4.196/linux/mkl cannot be used
>>>> I attach the new configure.log. Do you think there is something wrong with
>>>> the
>>>> mkl version that I'm trying to use? Or is it only related to petsc?
>>>> Cheers,
>>>> Samuel
>>>>>> Hi there,
>>>>>> I was wondering if you could help me with the correct configuration of
>>>>>> PETSc-dev version on a cluster (https://www.cscs.ch/)? I'm not sure which
>>>>>> information would be useful to you, but basically the problem seems to be
>>>>>> in
>>>>>> correctly compiling it with intel compiler and the existing mkl library.
>>>>>> The pre-installed mkl version is
>>>>>> intel/17.0.4.196
>>>>>> I have tried various things and finally, I got it at least to compile
>>>>>> with
>>>>>> the
>>>>>> following options (options chosen in reference to the mkl link
>>>>>> advisor...):
>>>>>> ./configure --with-fc=ftn --with-cc=cc --with-cxx=CC --with-debugging=0
>>>>>> --with-scalar-type=complex --download-scalapack --download-mumps=yes
>>>>>> --download-superlu --with-batch --known-mpi-shared-libraries=1
>>>>>> *--with-blaslapack-lib=*" ${MKLROOT}/lib/intel64/libmkl_blas95_lp64.a
>>>>>> ${MKLROOT}/lib/intel64/libmkl_lapack95_lp64.a -Wl,--start-group
>>>>>> ${MKLROOT}/lib/intel64/libmkl_intel_lp64.a
>>>>>> ${MKLROOT}/lib/intel64/libmkl_sequential.a
>>>>>> ${MKLROOT}/lib/intel64/libmkl_core.a -Wl,--end-group -lpthread -lm -ldl"
>>>>>> *--with-blaslapack-include*="[/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include,/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include/intel64/lp64]"
>>>>> Can you remove the above 2 options [--with-blaslapack-lib,
>>>>> --with-blaslapack-include] and use:
>>>>> --with-blas-lapack-dir=${MKLROOT}
>>>>> And see if you still have this problem?
>>>>> Satish
>>>>>> --known-64-bit-blas-indices=0
>>>>>> After compilation, when trying to compile
>>>>>> /users/lanthale/petsc-git/src/snes/examples/tutorials/ex5f I get linking
>>>>>> errors (attached). Would anyone be able to help me out here? I really
>>>>>> don't
>>>>>> have a good understanding of this.
>>>>>> I'm attaching the configuration.log file, as well as the linking errors
>>>>>> when
>>>>>> trying to compile ex5f.
>>>>>> Thank you very much in advance!
>>>>>> Best regards,
>>>>>> Samuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180424/409061a3/attachment-0001.html>
