[petsc-users] Problems with DMDAVecGetArrayF90 + Intel
Tue Apr 10 16:23:00 CDT 2018
I tried a few builds with:
    '--with-64-bit-indices=1',
    '--with-memalign=64',
    '--with-blaslapack-dir=/home/intel/18/compilers_and_libraries_2018.0.128/linux/mkl',
    '--with-cc=icc',
    '--with-fc=ifort',
    '--with-cxx=0',
    '--with-debugging=0',
    '--with-mpi=0',
And then changed the OPTFLAGS:
1.  'basic -g' - works fine
    'COPTFLAGS=-g',
    'FOPTFLAGS=-g',
2. 'avx512' - works fine
    'COPTFLAGS=-g -xMIC-AVX512 -O3',
    'FOPTFLAGS=-g -xMIC-AVX512 -O3',
3. 'avx2' - breaks.
    '--COPTFLAGS=-g -axcore-avx2',
    '--FOPTFLAGS=-g -axcore-avx2',
with a breakpoint at dmdavecrestorearrayf903_() in gdb - I see - the
stack is fine during the first call to dmdavecrestorearrayf903_() -
but is corrupted when it goes to the second call to
dmdavecrestorearrayf903_() i.e ierr=0x7fffffffb4a0 changes to
ierr=0x0]
Breakpoint 1, dmdavecrestorearrayf903_ (da=0x603098 <test_$DA1.0.1>, v=0x6030c0 <test_$VEC2.0.1>, a=0x401abd <test+2301>,
    ierr=0x7fffffffb4a0) at /home/petsc/petsc.barry-test/src/dm/impls/da/f90-custom/zda1f90.c:153
153     {
(gdb) where
#0  dmdavecrestorearrayf903_ (da=0x603098 <test_$DA1.0.1>, v=0x6030c0 <test_$VEC2.0.1>, a=0x401abd <test+2301>, ierr=0x7fffffffb4a0)
#1  0x0000000000401abd in test () at ex1f.F90:80
#2  0x00000000004011ae in main ()
#3  0x00007fffef1c3c05 in __libc_start_main () from /lib64/libc.so.6
#4  0x00000000004010b9 in _start ()
(gdb) c
Continuing.
Breakpoint 1, dmdavecrestorearrayf903_ (da=0x603098 <test_$DA1.0.1>, v=0x6030b8 <test_$VEC1.0.1>, a=0x401ada <test+2330>, ierr=0x0)
153     {
(gdb) where
#0  dmdavecrestorearrayf903_ (da=0x603098 <test_$DA1.0.1>, v=0x6030b8 <test_$VEC1.0.1>, a=0x401ada <test+2330>, ierr=0x0)
#1  0x0000000000401ada in test () at ex1f.F90:81
(gdb)
Its not clear to me why this happens. [and why it would work with -xMIC-AVX512 but breaks with -axcore-avx2].
Perhaps Richard, Jeff have better insight on this.
BTW: The above run is with:
bash-4.2$ icc --version
icc (ICC) 18.0.0 20170811
Satish
On Mon, 9 Apr 2018, Satish Balay wrote:
> I'm able to reproduce this problem on knl box [with the attached test code]. But it goes away if I rebuild without the option --with-64-bit-indices.
> Will have to check further..
> Satish
> On Thu, 5 Apr 2018, Randall Mackie wrote:
> > Dear PETSc users,
> > I’m curious if anyone else experiences problems using DMDAVecGetArrayF90 in conjunction with Intel compilers?
> > We have had many problems (typically 11 SEGV segmentation violations) when PETSc is compiled in optimize mode (with various combinations of options).
> > These same codes run valgrind clean with gfortran, so I assume this is an Intel bug, but before we submit a bug report I wanted to see if anyone else had similar experiences?
> > We have basically gone back and replaced our calls to DMDAVecGetArrayF90 with calls to VecGetArrayF90 and pass those pointers into a “local” subroutine that works fine.
> > In case anyone is curious, the attached test code shows this behavior when PETSc is compiled with the following options:
> > ./configure \
> >   --with-clean=1 \
> >   --with-debugging=0 \
> >   --with-fortran=1 \
> >   --with-64-bit-indices \
> >   --download-mpich=../mpich-3.3a2.tar.gz \
> >   --with-blas-lapack-dir=/opt/intel/mkl \
> >   --with-cc=icc \
> >   --with-fc=ifort \
> >   --with-cxx=icc \
> >   --FOPTFLAGS='-O2 -xSSSE3 -axcore-avx2' \
> >   --COPTFLAGS='-O2 -xSSSE3 -axcore-avx2' \
> >   --CXXOPTFLAGS='-O2 -xSSSE3 -axcore-avx2’ \
> > Thanks, Randy M.
