[petsc-users] Problems with DMDAVecGetArrayF90 + Intel
Satish Balay
balay at mcs.anl.gov
Mon Apr 9 18:59:21 CDT 2018
I'm able to reproduce this problem on knl box [with the attached test code]. But it goes away if I rebuild without the option --with-64-bit-indices.
Will have to check further..
Satish
On Thu, 5 Apr 2018, Randall Mackie wrote:
> Dear PETSc users,
> I’m curious if anyone else experiences problems using DMDAVecGetArrayF90 in conjunction with Intel compilers?
> We have had many problems (typically 11 SEGV segmentation violations) when PETSc is compiled in optimize mode (with various combinations of options).
> These same codes run valgrind clean with gfortran, so I assume this is an Intel bug, but before we submit a bug report I wanted to see if anyone else had similar experiences?
> We have basically gone back and replaced our calls to DMDAVecGetArrayF90 with calls to VecGetArrayF90 and pass those pointers into a “local” subroutine that works fine.
> In case anyone is curious, the attached test code shows this behavior when PETSc is compiled with the following options:
> ./configure \
> --with-clean=1 \
> --with-debugging=0 \
> --with-fortran=1 \
> --with-64-bit-indices \
> --download-mpich=../mpich-3.3a2.tar.gz \
> --with-blas-lapack-dir=/opt/intel/mkl \
> --with-cc=icc \
> --with-fc=ifort \
> --with-cxx=icc \
> --FOPTFLAGS='-O2 -xSSSE3 -axcore-avx2' \
> --COPTFLAGS='-O2 -xSSSE3 -axcore-avx2' \
> --CXXOPTFLAGS='-O2 -xSSSE3 -axcore-avx2’ \
> Thanks, Randy M.
