[petsc-users] --download-hdf5 and then compiling cgns
Klaij, Christiaan
C.Klaij at marin.nl
Thu Apr 5 04:09:19 CDT 2018
Satish, Gaetan, thanks for your suggestions. I've decided not to
use cmake for cgns, and that works fine with petsc's build of
hdf5.
Chris
dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | www.marin.nl<http://www.marin.nl>
[LinkedIn]<https://www.linkedin.com/company/marin> [YouTube] <http://www.youtube.com/marinmultimedia> [Twitter] <https://twitter.com/MARIN_nieuws> [Facebook] <https://www.facebook.com/marin.wageningen>
MARIN news: Kom zaterdag 10 november naar de open dag in Wageningen!<http://www.marin.nl/web/News/News-items/Kom-zaterdag-10-november-naar-de-open-dag-in-Wageningen.htm>
Sent: Thursday, March 29, 2018 6:43 PM
To: petsc-users
Cc: Klaij, Christiaan
Subject: Re: [petsc-users] --download-hdf5 and then compiling cgns
I have compiled CGNS3.3 with hdf from PETSc but not using cmake from CGNS. Here is what I used:
git clone https://github.com/CGNS/CGNS.git
cd CGNS/src
export CC=mpicc
export FC=mpif90
export FCFLAGS='-fPIC -O3'
export CFLAGS='-fPIC -O3'
export LIBS='-lz -ldl'
./configure --with-hdf5=$PETSC_DIR/$PETSC_ARCH --enable-64bit --prefix=/u/wk/gkenway/.local --enable-parallel --enable-cgnstools=yes --enable-shared
make -j 10
Hope that helps
Gaetan
On Thu, Mar 29, 2018 at 9:37 AM, Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
--download-hdf5 uses 'autoconf' build of hdf5 - and not cmake
build. [hdf5 provides both build tools].
This must be the reason why hdf5Config.cmake and hdf5-config.cmake
files might be missing.
You might be able to install hdf5 manually with cmake - and then build
cgns-3.3.1 with it.
Satish
On Thu, 29 Mar 2018, Klaij, Christiaan wrote:
> Satish,
> I've build petsc-3.8.3 with --download-hdf5 and this works
> fine. Now, I'm trying to compile cgns-3.3.1 and have it use the
> hdf5 library from petsc. Therefore, in the cmake configure I have
> set this option
> -D HDF5_DIR=/path/to/petsc/hdf5
> but cmake gives this message:
> CMake Warning at CMakeLists.txt:207 (find_package):
> Could not find a package configuration file provided by "HDF5" with any of
> the following names:
> hdf5Config.cmake
> hdf5-config.cmake
> and then falls back to the system's hdf5. Indeed there are no
> such files in /path/to/petsc/hdf5. Any idea on how to proceed
> from here?
> Chris
> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | http://www.marin.nl
> MARIN news: http://www.marin.nl/web/News/News-items/Comfort-draft-for-semisubmersible-yachts.htm
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180405/3cf38e0a/attachment.html>
Type: image/png
Desc: imagee7f06f.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180405/3cf38e0a/attachment.png>
Type: image/png
Desc: image720aad.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180405/3cf38e0a/attachment-0001.png>
Type: image/png
Desc: imageeef69a.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180405/3cf38e0a/attachment-0002.png>
Type: image/png
Desc: image92a631.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180405/3cf38e0a/attachment-0003.png>
