[petsc-users] A bad commit affects MOOSE
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Apr 3 16:57:51 CDT 2018
I would only implement it for hypre since we don't know if it is safe for other packages.
Best to insure the comm is freed as soon as possible (not waiting for PetscFinalize())
> On Apr 3, 2018, at 3:04 PM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> What about
> PetscCommGetPkgComm(MPI_Comm comm ,const char* package, MPI_Comm* pkgcomm)
> with a key for each of the external packages PETSc can use?
>> On Apr 3, 2018, at 10:56 PM, Kong, Fande <fande.kong at inl.gov> wrote:
>> I think we could add an inner comm for external package. If the same comm is passed in again, we just retrieve the same communicator, instead of MPI_Comm_dup(), for that external package (at least HYPRE team claimed this will be fine). I did not see any issue with this idea so far.
>> I might be missing something here
>> Fande,
>> On Tue, Apr 3, 2018 at 1:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Tue, 3 Apr 2018, Smith, Barry F. wrote:
>> > > On Apr 3, 2018, at 11:59 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
>> > >> Note that PETSc does one MPI_Comm_dup() for each hypre matrix. Internally hypre does at least one MPI_Comm_create() per hypre boomerAMG solver. So even if PETSc does not do the MPI_Comm_dup() you will still be limited due to hypre's MPI_Comm_create.
>> > >> I will compose an email to hypre cc:ing everyone to get information from them.
>> > > Actually I don't see any calls to MPI_Comm_dup() in hypre sources [there are stubs for it for non-mpi build]
>> > > There was that call to MPI_Comm_create() in the stack trace [via hypre_BoomerAMGSetup]
>> > This is what I said. The MPI_Comm_create() is called for each solver and hence uses a slot for each solver.
>> Ops sorry - misread the text..
>> Satish
