[petsc-users] A bad commit affects MOOSE
Kong, Fande fande.kong at inl.gov
Tue Apr 3 16:11:09 CDT 2018
It looks nice for me.
Fande,
On Tue, Apr 3, 2018 at 3:04 PM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> What about
> PetscCommGetPkgComm(MPI_Comm comm ,const char* package, MPI_Comm* pkgcomm)
> with a key for each of the external packages PETSc can use?
> On Apr 3, 2018, at 10:56 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> I think we could add an inner comm for external package. If the same comm
> is passed in again, we just retrieve the same communicator, instead of
> MPI_Comm_dup(), for that external package (at least HYPRE team claimed
> this will be fine).   I did not see any issue with this idea so far.
> I might be missing something here
> Fande,
> On Tue, Apr 3, 2018 at 1:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Tue, 3 Apr 2018, Smith, Barry F. wrote:
>> > > On Apr 3, 2018, at 11:59 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
>> > >>   Note that PETSc does one MPI_Comm_dup() for each hypre matrix.
>> Internally hypre does at least one MPI_Comm_create() per hypre boomerAMG
>> solver. So even if PETSc does not do the MPI_Comm_dup() you will still be
>> limited due to hypre's MPI_Comm_create.
>> > >>    I will compose an email to hypre cc:ing everyone to get
>> information from them.
>> > > Actually I don't see any calls to MPI_Comm_dup() in hypre sources
>> [there are stubs for it for non-mpi build]
>> > > There was that call to MPI_Comm_create() in the stack trace [via
>> hypre_BoomerAMGSetup]
>> >    This is what I said. The MPI_Comm_create() is called for each solver
>> and hence uses a slot for each solver.
>> Ops sorry - misread the text..
>> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/92d8902c/attachment.html>
