[petsc-users] A bad commit affects MOOSE
Kong, Fande
fande.kong at inl.gov
Tue Apr 3 15:56:29 CDT 2018
I think we could add an inner comm for external package. If the same comm
is passed in again, we just retrieve the same communicator, instead of
MPI_Comm_dup(), for that external package (at least HYPRE team claimed this
will be fine). I did not see any issue with this idea so far.
I might be missing something here
Fande,
On Tue, Apr 3, 2018 at 1:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 3 Apr 2018, Smith, Barry F. wrote:
> > > On Apr 3, 2018, at 11:59 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > >> Note that PETSc does one MPI_Comm_dup() for each hypre matrix.
> Internally hypre does at least one MPI_Comm_create() per hypre boomerAMG
> solver. So even if PETSc does not do the MPI_Comm_dup() you will still be
> limited due to hypre's MPI_Comm_create.
> > >> I will compose an email to hypre cc:ing everyone to get
> information from them.
> > > Actually I don't see any calls to MPI_Comm_dup() in hypre sources
> [there are stubs for it for non-mpi build]
> > > There was that call to MPI_Comm_create() in the stack trace [via
> hypre_BoomerAMGSetup]
> > This is what I said. The MPI_Comm_create() is called for each solver
> and hence uses a slot for each solver.
> Ops sorry - misread the text..
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/4e2400d1/attachment.html>
