[petsc-users] A bad commit affects MOOSE
Tue Apr 3 14:45:00 CDT 2018
On Tue, 3 Apr 2018, Smith, Barry F. wrote:
> >>   Note that PETSc does one MPI_Comm_dup() for each hypre matrix. Internally hypre does at least one MPI_Comm_create() per hypre boomerAMG solver. So even if PETSc does not do the MPI_Comm_dup() you will still be limited due to hypre's MPI_Comm_create.
> >>    I will compose an email to hypre cc:ing everyone to get information from them.
> > Actually I don't see any calls to MPI_Comm_dup() in hypre sources [there are stubs for it for non-mpi build]
> > There was that call to MPI_Comm_create() in the stack trace [via hypre_BoomerAMGSetup]
>    This is what I said. The MPI_Comm_create() is called for each solver and hence uses a slot for each solver.
Ops sorry - misread the text..
Satish
