[petsc-users] A bad commit affects MOOSE
Derek Gaston
friedmud at gmail.com
Tue Apr 3 12:48:46 CDT 2018
Sorry, should read: "any one MPI process is not involved in more than ~2000
*communicators*"
Derek
On Tue, Apr 3, 2018 at 11:47 AM Derek Gaston <friedmud at gmail.com> wrote:
> On Tue, Apr 3, 2018 at 10:31 AM Satish Balay <balay at mcs.anl.gov> wrote:
>> On Tue, 3 Apr 2018, Derek Gaston wrote:
>> > Which does bring up a point: I have been able to do solves before with
>> > ~50,000 separate PETSc solves without issue. Is it because I was
>> working
>> > with MVAPICH on a cluster? Does it just have a higher limit?
>> Don't know - but thats easy to find out with a simple test code..
> I get 2044 using mvapich on my cluster too.
> The only thing I can think of as to why those massive problems work for me
> is that any one MPI process is not involved in more than ~2000 processors
> (because the communicators are split as you go down the hierarchy). At
> most, a single MPI process will see ~hundreds of PETSc solves but not
> thousands.
> That said: it's just because of the current nature of the solves I'm doing
> - it's definitely possible to have that not be the case with MOOSE.
> Derek
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/e62ed42c/attachment.html>
