[petsc-users] A bad commit affects MOOSE
Derek Gaston
friedmud at gmail.com
Tue Apr 3 12:47:35 CDT 2018
On Tue, Apr 3, 2018 at 10:31 AM Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 3 Apr 2018, Derek Gaston wrote:
> > Which does bring up a point: I have been able to do solves before with
> > ~50,000 separate PETSc solves without issue. Is it because I was working
> > with MVAPICH on a cluster? Does it just have a higher limit?
> Don't know - but thats easy to find out with a simple test code..
I get 2044 using mvapich on my cluster too.
The only thing I can think of as to why those massive problems work for me
is that any one MPI process is not involved in more than ~2000 processors
(because the communicators are split as you go down the hierarchy). At
most, a single MPI process will see ~hundreds of PETSc solves but not
thousands.
That said: it's just because of the current nature of the solves I'm doing
- it's definitely possible to have that not be the case with MOOSE.
Derek
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/64dc5667/attachment.html>
