[petsc-users] read variables from a source file in petsc
Matthew Knepley
knepley at gmail.com
Tue Apr 3 05:53:56 CDT 2018
On Mon, Apr 2, 2018 at 10:52 PM, Sepideh Kavousi <skavou1 at lsu.edu> wrote:
> Hi all,
> I wrote a petsc code, and I defined my variables in a separate file,
> namely common.h, and common.c as following
> common.h:
> extern int i;
> extern int n;
> Notice that these declarations are inconsistent for the main file.
> common.c:
> #include <petsc.h>
> #include "common.h
> PetscScalar i; // Define i and initialize
> PetscScalar n; // Define n and initialize
> i=2.2;
> n=3.5;
> Now in my prog.c code I have:
> #include <petsc.h>
> #include <common.h>
> static char help[]="program main";
> int main (int argc, char **argv){
> PetscInitialize(&argc,&argv, (char*) 0,help);
> PetscPrintf(PETSC_COMM_WORLD,"i=%f!\n",a);
> PetscPrintf(PETSC_COMM_WORLD,"n=%f!\n",b) ;
> PetscFinalize();
> if my it was not using petsc and it was a normal c code, I could run it
> using the following command:
> gcc prog. c common.c
> but now that I am using petsc, I do not know how should I include common.c
> in my makefile.
> my makefile looks like this:
> include ${PETSC_DIR}/lib/petsc/conf/variables
> include ${PETSC_DIR}/lib/petsc/conf/rules
> prog: prog.o chkopts
> -${CLINKER} -o prog.out prog.o ${PETSC_LIB}
> ${RM} *.o
> You want
prog: prog.o common.o chkopts
-${CLINKER} -o prog.out prog.o common.o ${PETSC_LIB}
Matt
> .PHONY: distclean rune_1 test
> distclean:
> @rm -f *~ prog
> Thanks,
> Sepideh
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/5e994cd7/attachment.html>
