[petsc-users] mesh refinement PETSc3.5.4 with HYPRE
    Hao Zhang
    hbcbh1999 at gmail.com
    Fri Sep 29 20:19:35 CDT 2017
==31497== Use of uninitialised value of size 8
==31497==    at 0x85AEA9B: _itoa_word (in /lib64/libc-2.12.so)
==31497==    by 0x85B1652: vfprintf (in /lib64/libc-2.12.so)
==31497==    by 0x866AB4F: __vsnprintf_chk (in /lib64/libc-2.12.so)
==31497==    by 0x866AA89: __snprintf_chk (in /lib64/libc-2.12.so)
==31497==    by 0x10A847F6: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xD6A7D18: ompi_common_verbs_find_ports (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/libmca_common_verbs.so.0.2.3)
==31497==    by 0xD48BC1F: usnic_component_init (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/openmpi/mca_btl_usnic.so)
==31497==    by 0x7959D5E: mca_btl_base_select (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/libmpi.so.1.6.0)
==31497==    by 0xD079751: mca_bml_r2_component_init (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/openmpi/mca_bml_r2.so)
==31497==    by 0x79595B8: mca_bml_base_init (in
==31497==    by 0xE9B41B4: mca_pml_ob1_component_init (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/openmpi/mca_pml_ob1.so)
==31497==    by 0x796A07E: mca_pml_base_select (in
==31497==    by 0x791E253: ompi_mpi_init (in
==31497==    by 0x793C26F: PMPI_Init (in
==31497==    by 0x6B0652: pp_init (ppsub.c:178)
==31497==    by 0x54EAB2: FT_Init (fmap.c:385)
==31497==    by 0x40BD5E: main (iFluid.cpp:96)
==31497==
==31497== Conditional jump or move depends on uninitialised value(s)
==31497==    at 0x85AEAA5: _itoa_word (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0xD6A7D2E: ompi_common_verbs_find_ports (in
==31497==
==31497==    at 0xD6A7D59: ompi_common_verbs_find_ports (in
==31497==
==31497==    by 0xD48C752: usnic_component_init (in
==31497==
==31497==
==31497==    at 0xE316F5E: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE309719: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30B6C1: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30B203: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30B467: rdma_create_event_channel (in
==31497==    by 0xE0F1DBE: mca_btl_openib_build_rdma_addr_list (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/openmpi/mca_btl_openib.so)
==31497==    by 0xE0F35A9: rdmacm_component_init (in
==31497==    by 0xE0F2940: ompi_btl_openib_connect_base_init (in
==31497==    by 0xE0E6184: btl_openib_component_init (in
==31497==
==31497==    at 0xE316F6A: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0xE316FC9: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0xE316FD7: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0xE316F7C: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497== Syscall param write(buf) points to uninitialised byte(s)
==31497==    at 0x835C77D: ??? (in /lib64/libpthread-2.12.so)
==31497==    by 0xE30A677: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30AB7A: rdma_bind_addr (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30B254: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==  Address 0x7feffe9b8 is on thread 1's stack
==31497==
==31497==    by 0xE30A472: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30A688: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==  Address 0x7feffe860 is on thread 1's stack
==31497==
==31497==    at 0x4C29B6A: memcpy (mc_replace_strmem.c:119)
==31497==    by 0xE30A48B: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0x4C29B8C: memcpy (mc_replace_strmem.c:882)
==31497==
==31497==    at 0x4C29C18: memcpy (mc_replace_strmem.c:882)
==31497==
==31497==    at 0x4C29C3E: memcpy (mc_replace_strmem.c:882)
==31497==
==31497==    at 0x4C29C5B: memcpy (mc_replace_strmem.c:882)
==31497==
==31497==    by 0xE30A4A3: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0xE30A4F8: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    by 0xE30A592: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30A6B7: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    by 0xE30A05E: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30A0AD: rdma_destroy_id (in
==31497==    by 0xE30B269: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==  Address 0x7feffea70 is on thread 1's stack
==31497==
==31497==    at 0xE30A0B2: rdma_destroy_id (in
==31497==
==31497==    at 0xE30A0DA: rdma_destroy_id (in
==31497==
==31497==    at 0xE309DA5: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30A10C: rdma_destroy_id (in
==31497==
==31497==    at 0xE316F31: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE309E8B: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0xE316F35: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    by 0xE0F1DE1: mca_btl_openib_build_rdma_addr_list (in
==31497==
==31497==
==31497==
==31497==    by 0xE0F1E9E: mca_btl_openib_build_rdma_addr_list (in
==31497==  Address 0x7feffea48 is on thread 1's stack
==31497==
==31497==    by 0xE0F1F71: mca_btl_openib_build_rdma_addr_list (in
==31497==  Address 0x7feffeb00 is on thread 1's stack
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==    at 0xE30976C: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE30A501: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0xE3095DF: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE3097C3: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    at 0xE309601: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==
==31497==    by 0xDABACE1: ibv_cmd_dealloc_pd (in
/usr/lib64/libibverbs.so.1.0.0)
==31497==    by 0x10A846AC: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xE309E40: ??? (in /usr/lib64/librdmacm.so.1.0.0)
==31497==  Address 0x7feffead8 is on thread 1's stack
==31497==
==31497== Syscall param mmap(offset) contains uninitialised byte(s)
==31497==    at 0x865038A: mmap (in /lib64/libc-2.12.so)
==31497==    by 0x10A8454B: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xDAC0D8E: ibv_create_cq (in /usr/lib64/libibverbs.so.1.0.0)
==31497==    by 0xD6A8AB4: ompi_common_verbs_qp_test (in
==31497==    by 0xE0E2DEF: init_one_device (in
==31497==    by 0xE0E66B8: btl_openib_component_init (in
==31497==
==31497==    by 0xDABCABC: ibv_cmd_create_qp (in
==31497==    by 0x10A8406D: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xDAC0B71: ibv_create_qp (in /usr/lib64/libibverbs.so.1.0.0)
==31497==    by 0xD6A8A1C: make_qp (in
==31497==    by 0xD6A8AF2: ompi_common_verbs_qp_test (in
==31497==  Address 0x7feffe968 is on thread 1's stack
==31497==
==31497== Syscall param mmap(length) contains uninitialised byte(s)
==31497==    by 0x10A8412C: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==
==31497==    by 0xDABC45A: ibv_cmd_destroy_qp (in
==31497==    by 0x10A83EB5: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xD6A8A2B: make_qp (in
==31497==  Address 0x7feffe9b0 is on thread 1's stack
==31497==
==31497==    at 0xDABC48E: ibv_cmd_destroy_qp (in
==31497==
==31497== Syscall param munmap(length) contains uninitialised byte(s)
==31497==    at 0x86503B7: munmap (in /lib64/libc-2.12.so)
==31497==    by 0x10A83EEB: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==    by 0xD6A8AD8: ompi_common_verbs_qp_test (in
==31497==  Address 0x7feffea28 is on thread 1's stack
==31497==
==31497==    by 0xDABC5EA: ibv_cmd_destroy_cq (in
==31497==    by 0x10A84275: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xD6A8AE0: ompi_common_verbs_qp_test (in
==31497==  Address 0x7feffea00 is on thread 1's stack
==31497==
==31497==    at 0xDABC632: ibv_cmd_destroy_cq (in
==31497==
==31497==    at 0xDABC63B: ibv_cmd_destroy_cq (in
==31497==
==31497==    by 0x10A84297: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==    at 0xE0E3173: init_one_device (in
==31497==
==31497==    at 0xE0E318B: init_one_device (in
==31497==
==31497==    at 0xE0E351C: init_one_device (in
==31497==
==31497==    at 0xE0EF658: ompi_btl_openib_ini_query (in
==31497==    by 0xE0E353A: init_one_device (in
==31497==
==31497==    at 0xE0EF65E: ompi_btl_openib_ini_query (in
==31497==
==31497==    by 0x85DA3D9: vasprintf (in /lib64/libc-2.12.so)
==31497==    by 0x85BA347: asprintf (in /lib64/libc-2.12.so)
==31497==    by 0xE0E3872: init_one_device (in
==31497==
==31497==
==31497==    at 0xE0E3930: init_one_device (in
==31497==
==31497==    at 0xE0E393F: init_one_device (in
==31497==
==31497==    at 0xE0E258A: init_one_port (in
==31497==    by 0xE0E3CB0: init_one_device (in
==31497==
==31497==    at 0xE0E2638: init_one_port (in
==31497==
==31497==    at 0xE0E2642: init_one_port (in
==31497==
==31497==    at 0xE0E268A: init_one_port (in
==31497==
==31497==    by 0x85D4608: vsprintf (in /lib64/libc-2.12.so)
==31497==    by 0x85BA2B7: sprintf (in /lib64/libc-2.12.so)
==31497==    by 0xE0E2925: init_one_port (in
==31497==
==31497==
==31497==    at 0xD6A88FA: ompi_common_verbs_port_bw (in
==31497==    by 0xE0E2B9C: init_one_port (in
==31497==
==31497==    at 0xD6A8913: ompi_common_verbs_port_bw (in
==31497==
==31497==    at 0xD6A892D: ompi_common_verbs_port_bw (in
==31497==
==31497==    at 0xE0E2B14: init_one_port (in
==31497==
==31497==    at 0xE0E38FB: init_one_device (in
==31497==
==31497==    by 0xE0F5C9D: rdmacm_component_query (in
==31497==    by 0xE0F2B63:
ompi_btl_openib_connect_base_select_for_local_port (in
==31497==    by 0xE0E7216: btl_openib_component_init (in
==31497==
==31497==
==31497==
==31497==    by 0xE0F5DD8: rdmacm_component_query (in
==31497==  Address 0x7feffea78 is on thread 1's stack
==31497==
==31497==
==31497==    at 0xE0F1B05: mca_btl_openib_rdma_get_ipv4addr (in
==31497==    by 0xE0F5E08: rdmacm_component_query (in
==31497==
==31497==    by 0xE30AA40: rdma_listen (in /usr/lib64/librdmacm.so.1.0.0)
==31497==    by 0xE0F6032: rdmacm_component_query (in
==31497==  Address 0x7feffeb78 is on thread 1's stack
==31497==
==31497==    by 0xE30AA6F: rdma_listen (in /usr/lib64/librdmacm.so.1.0.0)
==31497==  Address 0x7feffea20 is on thread 1's stack
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==    by 0xE0F763C: udcm_component_query (in
==31497==
==31497==    by 0xE0F7668: udcm_component_query (in
==31497==
==31497==    by 0xDABAAE6: ibv_cmd_reg_mr (in
==31497==    by 0x10A84659: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xDAC10C2: ibv_reg_mr (in /usr/lib64/libibverbs.so.1.0.0)
==31497==    by 0xE0F770C: udcm_component_query (in
==31497==
==31497==    by 0xE0F77C4: udcm_component_query (in
==31497==
==31497==
==31497==    by 0xDABBF83: ibv_cmd_modify_qp (in
==31497==    by 0x10A83F34: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xDAC0913: ibv_modify_qp (in /usr/lib64/libibverbs.so.1.0.0)
==31497==    by 0xE0F7825: udcm_component_query (in
==31497==  Address 0x7feffea88 is on thread 1's stack
==31497==
==31497==    at 0x10A838FD: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xE0F7931: udcm_component_query (in
==31497==
==31497==    at 0x10A83920: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==    at 0x10A8393F: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==    at 0x10A83966: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==    at 0x10A83975: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==
==31497== More than 100 errors detected.  Subsequent errors
==31497== will still be recorded, but in less detail than before.
==31497==    by 0xDABA90C: ibv_cmd_req_notify_cq (in
==31497==    by 0xE0F7A91: udcm_component_query (in
==31497==
==31497== Thread 2:
==31497==    by 0xB83D2A6: send_bytes (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/openmpi/mca_oob_tcp.so)
==31497==    by 0xB83D6D4: mca_oob_tcp_send_handler (in
==31497==    by 0x97A69EB: opal_libevent2021_event_base_loop (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/libopen-pal.so.6.2.1)
==31497==    by 0x9507DAD: orte_progress_thread_engine (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/libopen-rte.so.7.0.5)
==31497==    by 0x8355A50: start_thread (in /lib64/libpthread-2.12.so)
==31497==    by 0x86539AC: clone (in /lib64/libc-2.12.so)
==31497==  Address 0xf43d11f is 239 bytes inside a block of size 512 alloc'd
==31497==    at 0x4C27C20: realloc (vg_replace_malloc.c:662)
==31497==    by 0x9774F72: opal_dss_buffer_extend (in
==31497==    by 0x9775BDC: opal_dss_copy_payload (in
==31497==    by 0x950C035: orte_grpcomm_base_pack_collective (in
==31497==    by 0xB62E613: process_allgather (in
/cm/shared/apps/openmpi/gcc/64/1.8.5/lib64/openmpi/mca_grpcomm_bad.so)
==31497==
==31497== Thread 1:
==31497==    by 0xE0E0205: mca_btl_openib_add_procs (in
==31497==    by 0xD078381: mca_bml_r2_add_procs (in
==31497==    by 0xE9B33F9: mca_pml_ob1_add_procs (in
==31497==    by 0x791E61F: ompi_mpi_init (in
==31497==  Address 0x7feffee14 is on thread 1's stack
==31497==
==31497==    at 0xE0EF977: btl_openib_async_command_done (in
==31497==    by 0xE0E021D: mca_btl_openib_add_procs (in
==31497==
==31497==    at 0xE0E0824: mca_btl_openib_add_procs (in
==31497==
==31497==    by 0xDABA9BF: ibv_cmd_create_cq (in
==31497==    by 0x10A84517: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xE0DEC77: adjust_cq (in
==31497==    by 0xE0DFBF9: mca_btl_openib_add_procs (in
==31497==  Address 0x7feffec18 is on thread 1's stack
==31497==
==31497==
==31497==    by 0xDABCEE1: ibv_cmd_create_srq (in
==31497==    by 0x10A83D16: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xDAC0C1B: ibv_create_srq (in
==31497==    by 0xE0E028B: mca_btl_openib_add_procs (in
==31497==  Address 0x7feffec58 is on thread 1's stack
==31497==
==31497==    by 0x10A83D67: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==
==31497==    by 0xE0E031C: mca_btl_openib_add_procs (in
==31497==
==31497==
==31497==
==31497==
==31497==
==31497==    at 0x10A83997: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497==    by 0xDABC3D6: ibv_cmd_modify_srq (in
==31497==    by 0x10A83B22: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xE0E0356: mca_btl_openib_add_procs (in
==31497==  Address 0x7feffec78 is on thread 1's stack
==31497==
==31497==    by 0xDABC52A: ibv_cmd_destroy_srq (in
==31497==    by 0x10A83A45: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==    by 0xE0E036B: mca_btl_openib_add_procs (in
==31497==  Address 0x7feffec70 is on thread 1's stack
==31497==
==31497==    at 0xDABC55B: ibv_cmd_destroy_srq (in
==31497==
==31497==    by 0x10A83A76: ??? (in /usr/lib64/libipathverbs-rdmav2.so)
==31497==
==31497== Invalid write of size 8
==31497==    at 0x643685: level_wave_func_Meniscus (imkcurve.c:1826)
==31497==    by 0x65299B: assign_two_comp_domain (imksurf.c:2046)
==31497==    by 0x64623B: make_level_surface (imksurf.c:245)
==31497==    by 0x5458AF: FT_InitIntfc3d (finit.c:2137)
==31497==    by 0x544CA3: FT_InitIntfc (finit.c:1853)
==31497==    by 0x40C072: main (iFluid.cpp:218)
==31497==  Address 0x7fe859c38 is on thread 1's stack
==31497==
==31497==    at 0x64368C: level_wave_func_Meniscus (imkcurve.c:1826)
==31497==  Address 0x7fe859c30 is on thread 1's stack
==31497==
==31497== Invalid read of size 8
==31497==    at 0x643693: level_wave_func_Meniscus (imkcurve.c:1831)
==31497==
==31497==    at 0x64372D: level_wave_func_Meniscus (imkcurve.c:1848)
==31497==  Address 0x7fe859c18 is on thread 1's stack
==31497==
==31497==    at 0x7ED3127: tan (in /lib64/libm-2.12.so)
==31497==
==31497==    at 0x643755: level_wave_func_Meniscus (imkcurve.c:1853)
==31497==
==31497==    at 0x643765: level_wave_func_Meniscus (imkcurve.c:1854)
==31497==
==31497==    at 0x643A7F: level_wave_func_Meniscus (imkcurve.c:1944)
==31497==
==31497==    at 0x643A92: level_wave_func_Meniscus (imkcurve.c:1944)
==31497==  Address 0x7feffecf0 is on thread 1's stack
==31497==
==31497==    at 0x643AEB: level_wave_func_Meniscus (imkcurve.c:1955)
==31497==
==31497==    at 0x428B9F:
Incompress_Solver_Smooth_Basis::setAdvectionDt_vd() (iFbasic.cpp:2799)
==31497==    by 0x4B8BB9:
Incompress_Solver_Smooth_3D_Cartesian::setInitialCondition_RSSY_vd(_LEVEL_FUNC_PACK*)
(iFcartsn3d.cpp:15253)
==31497==    by 0x40C485: main (iFluid.cpp:349)
==31497==
==31497==    at 0x428BA9:
==31497==
==31497==    at 0x85B00E3: vfprintf (in /lib64/libc-2.12.so)
==31497==    by 0x85BA189: printf (in /lib64/libc-2.12.so)
==31497==    by 0x486108:
Incompress_Solver_Smooth_3D_Cartesian::compDiffWithSmoothProperty_velocity_MAC_coupled_vd()
(iFcartsn3d.cpp:6101)
==31497==    by 0x4CBF0D:
Incompress_Solver_Smooth_3D_Cartesian::solve_vd(double)
(iFcartsn3d.cpp:18574)
==31497==    by 0x40C72E: ifluid_driver(_Front*,
Incompress_Solver_Smooth_Basis*, _F_BASIC_DATA*) (iFluid.cpp:419)
==31497==    by 0x40C4F3: main (iFluid.cpp:369)
==31497==
==31497==    at 0x85B0101: vfprintf (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x4ED737:
Incompress_Solver_Smooth_3D_Cartesian::computeSubgridModel_vd()
(iFcartsn3d.cpp:24519)
==31497==    by 0x4CBFBC:
(iFcartsn3d.cpp:18594)
==31497==
==31497==    at 0x4ED754:
==31497==
==31497==    at 0x85B4CF0: __printf_fp (in /lib64/libc-2.12.so)
==31497==    by 0x85B089F: vfprintf (in /lib64/libc-2.12.so)
==31497==    by 0x4ED9F7:
(iFcartsn3d.cpp:24549)
==31497==
==31497==    at 0x85B4F91: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85AE396: __mpn_extract_double (in /lib64/libc-2.12.so)
==31497==    by 0x85B51BD: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85AE39B: __mpn_extract_double (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85B59EC: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85B5A9D: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85B5C13: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85B5CA4: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85B625E: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x85B6242: __printf_fp (in /lib64/libc-2.12.so)
==31497==
==31497==    at 0x86465ED: ??? (in /lib64/libc-2.12.so)
==31497==    by 0x85DCAD2: _IO_file_write@@GLIBC_2.2.5 (in /lib64/
libc-2.12.so)
==31497==    by 0x85DE084: _IO_do_write@@GLIBC_2.2.5 (in /lib64/libc-2.12.so
==31497==    by 0x85DD287: _IO_file_sync@@GLIBC_2.2.5 (in /lib64/
libc-2.12.so)
==31497==    by 0x85D1999: fflush (in /lib64/libc-2.12.so)
==31497==    by 0x6FACFA: preserve_front_advance_front3d (fadv.c:2255)
==31497==    by 0x6FA14E: mixed_advance_front3d (fadv.c:1895)
==31497==    by 0x6F9B2D: advance_front3d_tracking_control (fadv.c:1703)
==31497==    by 0x54E119: FrontAdvance (fmap.c:142)
==31497==    by 0x54DF27: FT_Propagate (fmap.c:80)
==31497==    by 0x40CA37: ifluid_driver(_Front*,
Incompress_Solver_Smooth_Basis*, _F_BASIC_DATA*) (iFluid.cpp:512)
==31497==  Address 0x412308a is not stack'd, malloc'd or (recently) free'd
==31497==
On Fri, Sep 29, 2017 at 8:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Can you run this code with valgrind and send the log?
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> Satish
> On Sat, 30 Sep 2017, Hao Zhang wrote:
> > I've modified my source code accordingly using PETSc 3.8.0. It seems no
> > more useful info got printed out.
> > On Fri, Sep 29, 2017 at 8:15 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> > > I'm using -fp_trap as I run the simulation. the output only gives
> > > floating point exception
> > > It doesn't matter coarse grid or medium grid or more refined grid. the
> > > program crashed right away.
> > > On Fri, Sep 29, 2017 at 12:19 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >>   Please upgrade to the latest 3.8 version of PETSc. and then run with
> > >> -fp_trap
> > >>    This message is usually an indication that a NaN or Inf got into
> the
> > >> numerical computation. Using the latest PETSc will make it much
> easier to
> > >> track down.
> > >>   Barry
> > >> > On Sep 28, 2017, at 8:57 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> > >> > I'm experiencing error when doing mesh refinement(mesh x2 for X, Y
> and
> > >> Z direction) for 3D poisson problem.
> > >> > PETSc produces no errors when no mesh refinement. I've pasted some
> > >> debugging info here. Please advise.
> > >> > [0]PETSC ERROR: --------------------- Error Message
> > >> > [0]PETSC ERROR: Invalid argument
> > >> > [0]PETSC ERROR: Scalar value must be same on all processes,
> argument # 3
> > >> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
> > >> for trouble shooting.
> > >> > [0]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> > >> > [0]PETSC ERROR: /home/haozhang/FT.NO.FULL/iFluid/iFluid on a
> > >> arch-linux2-c-debug named vn18 by haozhang Thu Sep 28 23:47:39 2017
> > >> > [0]PETSC ERROR: Configure options --with-mpi-dir=/cm/shared/
> > >> --download-fblaslapack=/home/haozhang/tmp/fblaslapack-3.4.2.tar.gz
> > >> --download-hypre=/home/haozhang/tmp/hypre-2.9.1a.tar.gz
> > >> --with-valgrind-include=/home/haozhang/include/valgrind/
> > >> > [0]PETSC ERROR: #1 VecAXPBYPCZ() line 731 in
> > >> /home/haozhang/tmp/petsc-3.5.4_HYPRE/src/vec/vec/interface/rvector.c
> > >> > [0]PETSC ERROR: #2 KSPSolve_BCGS() line 87 in
> > >> /home/haozhang/tmp/petsc-3.5.4_HYPRE/src/ksp/ksp/impls/bcgs/bcgs.c
> > >> > [0]PETSC ERROR: #3 KSPSolve() line 460 in
> > >> _HYPRE/src/ksp/ksp/interface/itfunc.c
> > >> > [vn18:99838] *** Process received signal ***
> > >> > [vn18:99838] Signal: Aborted (6)
> > >> > [vn18:99838] Signal code:  (-6)
> > >> > [vn18:99848] *** Process received signal ***
> > >> > [vn18:99849] *** Process received signal ***
> > >> > [vn18:99849] Signal: Aborted (6)
> > >> > [vn18:99849] Signal code:  (-6)
> > >> > [vn18:99848] Signal: Aborted (6)
> > >> > [vn18:99848] Signal code:  (-6)
> > >> > [vn18:99838] [ 0] /lib64/libpthread.so.0(+0xf790)[0x2aaaadbb4790]
> > >> > [vn18:99838] [ 1] [vn18:99848] [ 0] /lib64/libpthread.so.0(+0xf790
> > >> )[0x2aaaadbb4790]
> > >> > [vn18:99848] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x2aaaaddf5625]
> > >> > [vn18:99838] [ 2] /lib64/libc.so.6(abort+0x175)[0x2aaaaddf6e05]
> > >> > [vn18:99838] [ 3] [vn18:99849] [ 0] /lib64/libpthread.so.0(+0xf790
> > >> )[0x2aaaadbb4790]
> > >> > [vn18:99849] [ 1] [vn15:122106] *** Process received signal ***
> > >> > [vn15:122106] Signal: Aborted (6)
> > >> > [vn15:122106] Signal code:  (-6)
> > >> > [vn18:99848] [ 2] /lib64/libc.so.6(abort+0x175)[0x2aaaaddf6e05]
> > >> > [vn18:99848] [ 3] /home/haozhang/tmp/petsc-3.5.4
> > >> _HYPRE/arch-linux2-c-debug/lib/libpetsc.so.3.5(PetscTraceBac
> > >> kErrorHandler+0x503)[0x2aaaaae1d7e1]
> > >> > [vn18:99838] [ 4] /lib64/libc.so.6(gsignal+0x35)[0x2aaaaddf5625]
> > >> > [vn18:99849] [ 2] /lib64/libc.so.6(abort+0x175)[0x2aaaaddf6e05]
> > >> > [vn18:99849] [ 3] [vn15:122107] *** Process received signal ***
> > >> > [vn15:122107] Signal: Aborted (6)
> > >> > [vn15:122107] Signal code:  (-6)
> > >> > [vn16:86295] *** Process received signal ***
> > >> > [vn16:86295] Signal: Aborted (6)
> > >> > [vn16:86295] Signal code:  (-6)
> > >> > [vn18:99824] *** Process received signal ***
> > >> > [vn18:99824] Signal: Aborted (6)
> > >> > [vn18:99824] Signal code:  (-6)
> > >> > [vn18:99844] *** Process received signal ***
> > >> > [vn18:99844] Signal: Aborted (6)
> > >> > [vn18:99844] Signal code:  (-6)
> > >> > /home/haozhang/tmp/petsc-3.5.4_HYPRE/arch-linux2-c-debug/lib
> > >> /libpetsc.so.3.5(PetscError+0x338)[0x2aaaaae183b3]
> > >> > Hao Zhang
> > >> > Dept. of Applid Mathematics and Statistics,
> > >> > Stony Brook University,
> > >> > Stony Brook, New York, 11790
> > > Hao Zhang
Hao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170929/9c9cb81b/attachment-0001.html>
