[petsc-users] Access to submatrix owned by an other processor
Matthew Knepley
knepley at gmail.com
Mon Sep 25 05:15:31 CDT 2017
On Mon, Sep 25, 2017 at 4:26 AM, Benedusi Pietro <pietro.benedusi at usi.ch>
wrote:
> Dear all,
> there is a way to access an arbitrary block of a parallel matrix? It
> should work also in the case where the block is owned by an other processor.
> I have seen that you can use MatCreateRedundantMatrix() to copy the entire
> matrix in a processor, but this solution is not very efficient if I just
> need a (small) block of it.
> I have also tried to use MatGetSubMatrix() but does not seem to work.
Why does MatGetSubMatrix() not work?
Matt
> Thank you very much for any help,
> Pietro
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170925/17cd7966/attachment.html>
