[petsc-users] Access to submatrix owned by an other processor
    Benedusi Pietro
    pietro.benedusi at usi.ch
    Mon Sep 25 03:26:37 CDT 2017
Dear all,
there is a way to access an arbitrary block of a parallel matrix? It should work also in the case where the block is owned by an other processor.
I have seen that you can use MatCreateRedundantMatrix() to copy the entire matrix in a processor, but this solution is not very efficient if I just need a (small) block of it.
I have also tried to use MatGetSubMatrix() but does not seem to work.
Thank you very much for any help,
Pietro
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170925/58c24fef/attachment.html>
