[petsc-users] Using factored complex matrices from MUMPS as a preconditioner in PETSC
Barry Smith
bsmith at mcs.anl.gov
Sat Sep 23 20:45:04 CDT 2017
> On Sep 23, 2017, at 8:38 PM, Evan Um <evanum at gmail.com> wrote:
> Dear PETSC Users,
> My system matrix comes from finite element modeling and is complex and unstructured. Its typical size is a few millions-by a few millions. I wondering if I can use MUMPS parallel direct solver as a preconditioner in PETSC. For example, I want to pass factored matrices to Krylov iterative solvers such as QMR. Is there any PETSC+MUMPS example code for the purpose?
You don't pass factored matrices you just pass the original matrix and use -pc_type lu -pc_factor_mat_solver_package mumps
> Can PETSC call the latest MUMPS that supports block low rank approximation?
No, send us info on it and we'll see if we can add an interface
> In advance, thank you very much for your comments.
> Best,
> Evan
