[petsc-users] SNES ex12 visualization
Jed Brown jed at jedbrown.org
Thu Sep 14 11:29:15 CDT 2017
"Kong, Fande" <fande.kong at inl.gov> writes:
>> Given the way I/O is structured on big machines, we believe the multiple
>> file route is a huge mistake. Also, all our measurements
>> say that sending some data on the network is not noticeable given the disk
>> access costs.
> I have slightly different things here. We tried the serial output, it looks
> really slow for large-scale problems, and the first processor often runs
> out of memory because of gathering all data from other processor cores. The
> parallel IO runs smoothly and much faster than I excepted. We have done
> experiments with ten thousands  of cores for a problem with 1 billion of
> unknowns. I did not see any concern so far.
I think there are two different issues here.  Writing a separate file
per MPI rank (often also per time step, etc.) creates a filesystem
*metadata* bottleneck.  It's the open() and close() that are more
painful than the write() when you have lots of files.  (You'd also want
to be careful about your naming convention because merely running "ls"
on a directory with many files is usually quite painful.)
MPI-IO collectives offer a solution -- each rank writes parts of a file
efficiently using the parallel file system.  MPI-IO was introduced in
MPI-2 (standardized in 1997) and PETSc has thus far avoided a hard
dependency on this standard because some implementations were very slow
to adopt it.  In my opinion, any IO in PETSc that is intended to be
highly scalable should use MPI-IO.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170914/a67a3e55/attachment.sig>
