[petsc-users] Fwd: direct solvers on KNL
Matthew Knepley
knepley at gmail.com
Fri Sep 1 08:15:51 CDT 2017
On Fri, Sep 1, 2017 at 7:40 AM, Jakub Kruzik <jakub.kruzik at vsb.cz> wrote:
> Hi,
> I am looking at a single node performance of MUMPS and SuperLU on KNL 7230
> (on Theta). I am using KSP example ex2 (http://www.mcs.anl.gov/petsc/
> petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html) with m X n =
> 2880 x 2880. KNL runs in cache and quad modes.
> Times in seconds for 24 cores:
> mumps: 279
> superlu: 326
> cg: 116
> Times in seconds for 64 cores:
> mumps: 316
> superlu: 410
> cg : 49
> The performance for 24 cores is OK - both direct solvers are roughly 3.5
> times slower than 2x E5-2680v3. (According to people from Intel, the single
> core performance of KNL is about 3-4 times lower than that of E5-2680v3).
> However, strong scalability is really bad.
> I am using cray-petsc/3.7.6.0 module. I tried my own PETSc compilation
> with MKL and MUMPS/SuperLU installed by PETSc configure but the results are
> similar.
> Please find attached Theta submission script and logs for KNL and Haswells.
> Why the performance of direct solvers on a full node is so bad?
Admittedly it was for different computations, but we saw strong scaling
degradation after 32 cores of KNL
in https://arxiv.org/abs/1705.09907, and we also saw strong scaling tail
off as the problem size got this small
in https://arxiv.org/abs/1705.03625
Matt
> Best,
> Jakub
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170901/5d7888bb/attachment.html>
