[petsc-users] configuration error
Tue Oct 31 16:32:46 CDT 2017
I've already replied to this issue
Try a fresh build - and do not reuse --prefix for different version builds.
Have you tried doing this?
Satish
On Tue, 31 Oct 2017, Manav Bhatia wrote:
> Thanks, Barry.
> Does this also address the mumps compilation issue that I had shared in the same thread:
> mumps_c.c:307:53: error: no member named 'nnz' in 'CMUMPS_STRUC_C'; did you mean 'nz'?
>         mumps_par->n=0; mumps_par->nz=0; mumps_par->nnz=0; mumps_par->nz_loc=0; mumps_par->nnz_loc=0; mumps_par->nelt=0;mumps_par->instance_number=0;mumps_par->deficiency=0;mumps_par->lwk_user=0;mumps_par->size_schur=0;mumps_par->lrhs=0; mumps_par->lredrhs=0; mumps_par->nrhs=0; mumps_par->nz_rhs=0; mumps_par->lsol_loc=0;
>                                                     nz
> /Users/manav/Documents/codes/numerical_lib/petsc/include/cmumps_c.h:56:20: note: 'nz' declared here
>     MUMPS_INT      nz;
> mumps_c.c:307:92: error: no member named 'nnz_loc' in 'CMUMPS_STRUC_C'; did you mean 'nz_loc'?
>        nz_loc
> /Users/manav/Documents/codes/numerical_lib/petsc/include/cmumps_c.h:62:20: note: 'nz_loc' declared here
>     MUMPS_INT      nz_loc;
> mumps_c.c:419:42: error: no member named 'nnz' in 'CMUMPS_STRUC_C'; did you mean 'nz'?
>           &(mumps_par->nz), &(mumps_par->nnz), irn, &irn_avail, jcn, &jcn_avail, a, &a_avail,
>                                          nz
>     MUMPS_INT      nz;
> mumps_c.c:420:46: error: no member named 'nnz_loc' in 'CMUMPS_STRUC_C'; did you mean 'nz_loc'?
>           &(mumps_par->nz_loc), &(mumps_par->nnz_loc), irn_loc, &irn_loc_avail, jcn_loc, &jcn_loc_avail,
>                                              nz_loc
>     MUMPS_INT      nz_loc;
> mumps_c.c:419:29: warning: incompatible pointer types passing 'int *' to parameter of type 'int64_t *' (aka 'long long *') [-Wincompatible-pointer-types]
> mumps_c.c:99:28: note: passing argument to parameter 'nnz' here
>            MUMPS_INT8     *nnz,
> mumps_c.c:420:33: warning: incompatible pointer types passing 'int *' to parameter of type 'int64_t *' (aka 'long long *') [-Wincompatible-pointer-types]
> mumps_c.c:107:28: note: passing argument to parameter 'nnz_loc' here
>            MUMPS_INT8     *nnz_loc,
> 2 warnings and 4 errors generated.
> > On Oct 31, 2017, at 4:25 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> >  Manav,
> >    Thanks for reporting the problem
> >  Fande,
> >    Thanks for the pointer.
> >    Satish determined the correct long term fix and it is in the branch barry/fix-lto_library-option-maint and will be put in the maint branch and master branch if it passes the testing tonight.
> >   Barry
> >> On Oct 30, 2017, at 11:36 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> >> We had exactly the same issue when upgraded compilers.  I guess this is somehow related to gfortran.  A simple way to work around for us is to change if with_rpath: to  if False at line 54 of config/BuildSystem/config/libraries.py.
> >> Not sure if it works for you.
> >> Fande,
> >> On Mon, Oct 30, 2017 at 10:14 AM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> >> Hi,
> >>  I am trying to install pets 3.8 on a new MacBook machine with OS 10.13. I have installed openmpi from macports and I am getting this error on configuration. Attached is also the configure.log file.
> >>  I am not sure how to proceed with this. Any advice will be greatly appreciated!
> >> Regards,
> >> Manav
> >>             Configuring PETSc to compile on your system
> >> ===============================================================================        ***** WARNING: Using default optimization C flags -g -O3        You might consider manually setting optimal optimization flags for your system with        COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        ***** WARNING: Using default C++ optimization flags -g -O3        You might consider manually setting optimal optimization flags for your system with        CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        ***** WARNING: Using default FORTRAN optimization flags -g -O        You might consider manually setting optimal optimization flags for your system with        FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        WARNING! Compiling PETSc with no debugging, this should        only be done for timing and production runs. All development should        be done when configured using --with-debugging=1        ===============================================================================        TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:171)        *******************************************************************************
> >>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> >> C libraries cannot directly be used from Fortran
