[petsc-users] configuration error
Kong, Fande fande.kong at inl.gov
Mon Oct 30 11:36:45 CDT 2017
We had exactly the same issue when upgraded compilers.  I guess this is
somehow related to gfortran.  A simple way to work around for us is to
change* if with_rpath*: to * if False *at line 54 of
config/BuildSystem/config/libraries.py.
Not sure if it works for you.
Fande,
On Mon, Oct 30, 2017 at 10:14 AM, Manav Bhatia <bhatiamanav at gmail.com>
wrote:
> Hi,
>   I am trying to install pets 3.8 on a new MacBook machine with OS 10.13.
> I have installed openmpi from macports and I am getting this error on
> configuration. Attached is also the configure.log file.
>   I am not sure how to proceed with this. Any advice will be greatly
> appreciated!
> Regards,
> Manav
>              Configuring PETSc to compile on your system
>   ***** WARNING: Using default optimization C flags -g -O3
>     You might consider manually setting optimal optimization flags for your
> system with
>       COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for
> examples
>   ***** WARNING: Using default C++ optimization flags -g -O3
> system with
>       CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py
> for examples
>   ***** WARNING: Using default FORTRAN optimization flags -g -O
> system with
>       FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for
> examples
>             WARNING! Compiling PETSc with no debugging, this should
>                     only be done for timing and production runs. All
> development should
>                             be done when configured using
> --with-debugging=1
>                                                   TESTING: checkCLibraries
> from config.compilers(config/BuildSystem/config/compilers.py:171)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> C libraries cannot directly be used from Fortran
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171030/bdc10f26/attachment.html>
