[petsc-users] configuration error
Manav Bhatia
bhatiamanav at gmail.com
Mon Oct 30 11:14:11 CDT 2017
I am trying to install pets 3.8 on a new MacBook machine with OS 10.13. I have installed openmpi from macports and I am getting this error on configuration. Attached is also the configure.log file.
I am not sure how to proceed with this. Any advice will be greatly appreciated!
Manav
Configuring PETSc to compile on your system
=============================================================================== ***** WARNING: Using default optimization C flags -g -O3 You might consider manually setting optimal optimization flags for your system with COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples =============================================================================== =============================================================================== ***** WARNING: Using default C++ optimization flags -g -O3 You might consider manually setting optimal optimization flags for your system with CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples =============================================================================== =============================================================================== ***** WARNING: Using default FORTRAN optimization flags -g -O You might consider manually setting optimal optimization flags for your system with FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples =============================================================================== =============================================================================== WARNING! Compiling PETSc with no debugging, this should only be done for timing and production runs. All development should be done when configured using --with-debugging=1 =============================================================================== TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:171) *******************************************************************************
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
C libraries cannot directly be used from Fortran
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171030/276e4b10/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171030/276e4b10/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171030/276e4b10/attachment-0003.html>
