[petsc-users] Matload with given parallel layout
Wed Oct 25 05:13:28 CDT 2017
On Wed, Oct 25, 2017 at 6:10 AM, Karin&NiKo <niko.karin at gmail.com> wrote:
> Thank you very much for your answer.
> Is there an example in the PETSc tests that shows how to prescribe the
> layout of the Mat that is passed to MatLoad()? I see how to specify a local
> size with MatSetSize but I do not see how to assign an entry of the Mat to
> a given process...
Mat object only have contiguous division of rows on processes, so
specifying the size of each partition is all you can do.
   Matt
> Thanks,
> Nicolas
> 2017-10-25 11:40 GMT+02:00 Matthew Knepley <knepley at gmail.com>:
>> On Wed, Oct 25, 2017 at 4:32 AM, Karin&NiKo <niko.karin at gmail.com> wrote:
>>> Dear PETSc team,
>>> I have a code that creates a parallel matrix based on domain
>>> decomposition. I serialize this matrix with MatView.
>>> Then, I would like to relaod it with MatLoad but not leaving PETSc
>>> decide the parallel layout but rather use the original distribution of the
>>> degrees of freedom.
>>> Does MatLoad help to do that? Shall  I use the IS of the local/global
>>> mapping ?
>> You can prescribe the layout of the Mat that is passed to MatLoad().
>> However, if you are asking that the original
>> layout be stored in the file, we do not do that. It could be made to work
>> by writing the layout to the .info file and
>> then having the option call MatSetSizes() on load. Should not be much
>> code.
>>   Thanks,
>>      Matt
>>> I look forward to reading you,
>>> Nicolas
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171025/e153d103/attachment.html>
