[petsc-users] Matload with given parallel layout
Karin&NiKo niko.karin at gmail.com
Wed Oct 25 05:10:32 CDT 2017
Thank you very much for your answer.
Is there an example in the PETSc tests that shows how to prescribe the
layout of the Mat that is passed to MatLoad()? I see how to specify a local
size with MatSetSize but I do not see how to assign an entry of the Mat to
a given process...
Nicolas
2017-10-25 11:40 GMT+02:00 Matthew Knepley <knepley at gmail.com>:
> On Wed, Oct 25, 2017 at 4:32 AM, Karin&NiKo <niko.karin at gmail.com> wrote:
>> Dear PETSc team,
>> I have a code that creates a parallel matrix based on domain
>> decomposition. I serialize this matrix with MatView.
>> Then, I would like to relaod it with MatLoad but not leaving PETSc decide
>> the parallel layout but rather use the original distribution of the degrees
>> of freedom.
>> Does MatLoad help to do that? Shall  I use the IS of the local/global
>> mapping ?
> You can prescribe the layout of the Mat that is passed to MatLoad().
> However, if you are asking that the original
> layout be stored in the file, we do not do that. It could be made to work
> by writing the layout to the .info file and
> then having the option call MatSetSizes() on load. Should not be much code.
>   Thanks,
>      Matt
>> I look forward to reading you,
>> Nicolas
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171025/2f30097b/attachment-0001.html>
