[petsc-users] "Must select a target sorting criterion if using shift-and-invert"
Sat Oct 21 07:27:09 CDT 2017
On Sat, Oct 21, 2017 at 2:20 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> This was added in 3.8 to check the common case when people incorrectly
> sets shift-and-invert with EPS_SMALLEST_MAGNITUDE. To compute smallest
> eigenvalues with shift-and-invert the correct way is to set target=0 and
> which=EPS_TARGET_MAGNITUDE. See for instance
> http://slepc.upv.es/documentation/current/src/eps/
> examples/tutorials/ex13.c.html
Jose, one thing we are trying to do in PETSc now is to give the options to
fix a problem (or at least representative options)
directly in the error message. Or maybe a pointer to the relevant manual or
tutorial section. This gives users a hand up.
     Matt
> Jose
> > El 21 oct 2017, a las 1:51, Matthew Knepley <knepley at gmail.com>
> escribió:
> > On Fri, Oct 20, 2017 at 7:43 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Hi All,
> > I am trying to solve a generalized eigenvalue problem (using SLEPc) with
> "-eps_type krylovschur -st_type sinvert". I got an error message: "Must
> select a target sorting criterion if using shift-and-invert".
> > Not sure how to proceed.  I do not quite understand this sentence.
> > You need to know how to choose the shift. So for instance you want the
> smallest eigenvalues, or the closest to zero, etc.
> > I don't know the options, but they are in the manual.
> >    Matt
> > Fande,
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171021/7b50c4a8/attachment.html>
