[petsc-users] "Must select a target sorting criterion if using shift-and-invert"
Fri Oct 20 18:51:23 CDT 2017
On Fri, Oct 20, 2017 at 7:43 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> Hi All,
> I am trying to solve a generalized eigenvalue problem (using SLEPc) with
> "-eps_type krylovschur -st_type sinvert". I got an error message: "Must
> select a target sorting criterion if using shift-and-invert".
> Not sure how to proceed.  I do not quite understand this sentence.
You need to know how to choose the shift. So for instance you want the
smallest eigenvalues, or the closest to zero, etc.
I don't know the options, but they are in the manual.
   Matt
> Fande,
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171020/e2be7341/attachment.html>
