[petsc-users] Distributing already assembled stiffness matrix
Matthew Knepley
knepley at gmail.com
Thu Oct 19 09:56:27 CDT 2017
On Thu, Oct 19, 2017 at 10:52 AM, Jaganathan, Srikrishna <
srikrishna.jaganathan at fau.de> wrote:
> Thanks a lot for your detailed reply, it was very slow to insert values
> using MatSetValues , I guess its due to lack of preallocation. I still
> couldn't figure out how to calculate the parameters required to preallocate
> MatMPIAIJ. So I have the nnz array for serial preallocation and this is
> accurate. So is there any rule of thumb to arrive at decent numbers for
> d_nnz and o_nnz from nnz array ?
Yes. The d_nnz array wants nonzero that occur in the diagonal block. Thus,
if your process owns rows [rStart, rEnd) then
d_nnz is the number of nonzeros in a row that lie in columns [rStart,
rEnd). The rest of the nonzeros in that row are counted
in o_nnz.
Matt
> On 2017-10-19 14:41, Mark Adams wrote:
>> On Wed, Oct 18, 2017 at 8:18 AM, Jaganathan, Srikrishna <
>> Thanks for your response, its helpful.
>>> I do have few more questions, most of my matrices are of compressed row
>>> storage format.
>>> 1)So when I was creating sequentially , I just used
>>> MatCreateSeqAIJWithArrays , but the same for MPI version is quite
>>> confusing
>>> to use. I don't understand how to decide on the local rows(it would be
>>> really helpful if there is an example) .
>> You don't use local row indices (you but you don't want to). The code does
>> not change. As Jed says don't use MatCreateSeqAIJWithArrays. Just use
>> MatCreate. This is from ksp ex56.c:
>> /* create stiffness matrix */
>> ierr = MatCreate(comm,&Amat);CHKERRQ(ierr);
>> ierr = MatSetSizes(Amat,m,m,M,M);CHKERRQ(ierr);
>> if (!test_late_bs) {
>> ierr = MatSetBlockSize(Amat,3);CHKERRQ(ierr);
>> ierr = MatSetType(Amat,MATAIJ);CHKERRQ(ierr);
>> ierr = MatSeqAIJSetPreallocation(Amat,0,d_nnz);CHKERRQ(ierr);
>> ierr = MatMPIAIJSetPreallocation(Amat,0,d_nnz,0,o_nnz);CHKERRQ(ierr);
>> You can preallocate with an estimate (upper bound). See the documentation
>> for MatMPIAIJSetPreallocation (Google it).
>> You then run your code on one processor and PETSc will distribute it. Now
>> you just add values with (i,j,value) with MatSetValues (Google it). You
>> will find that it is very simple.
>> Now, this simple way will just chop your domain up in a dumb way. If you
>> have a regular grid then you will get a 1D partitioning, which will work
>> for a while. Otherwise you can partition this matrix. Bat that is another
>> story. You want to start with this simple way anyway.
>>> 2)When I also tried using MatSetValues it doesn't seem to use the same
>>> indexing as compressed row storage format.What type of indexing should be
>>> used when MatSetValues are used and called from rank 0 for CRS Matrices?
>>> On 2017-10-18 13:33, Jed Brown wrote:
>>> Easiest is to assemble into a distributed matrix from rank 0. So
>>>> instead of calling MatCreate using PETSC_COMM_SELF, use a parallel
>>>> communicator (like PETSC_COMM_WORLD). It is fine if only rank 0 calls
>>>> MatSetValues, but all processes must call MatAssemblyBegin/End.
>>>> "Jaganathan, Srikrishna" <srikrishna.jaganathan at fau.de> writes:
>>>> Hello,
>>>>> I have been trying to distribute a already existing stiffness matrix in
>>>>> my FEM code to petsc parallel matrix object , but I am unable to find
>>>>> any documentation regarding it. It was quite straightforward to create
>>>>> a
>>>>> sequential petsc matrix object and everything was working as intended.I
>>>>> have read some of the user comments in the mailing lists regarding
>>>>> similar situation and most of the times the solution suggested is to
>>>>> create stiffness matrix from the the mesh in distributed format. Since
>>>>> its a little difficult in my case to pass the mesh data in the code ,
>>>>> is
>>>>> there anyway to distribute already existing stiffness matrix ?
>>>>> Thanks and Regards
>>>>> Srikrishna Jaganathan
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171019/a3ccdda4/attachment.html>
