[petsc-users] Issue of mg_coarse_ksp not converge
Mark Adams
mfadams at lbl.gov
Mon Oct 2 12:49:04 CDT 2017
Well that is strange, the PETSc tests work.
Wenbo, could you please:
> git clone -b gamg-fix-eig-err https://bitbucket.org/petsc/petsc petsc2
> cd petsc2
and reconfigure, make, and then run your test without the
-st_gamg_est_ksp_error_if_not_converged 0 fix, and see if this fixes the
problem.
Don't forget to set PETSC_DIR=..../petsc2
If you have time and this works, you could do a 'git checkout master' and
remake, and retest. You should not have to reconfigure. I have tested
master on petsc tests. I don't understand how this happened.
On Mon, Oct 2, 2017 at 12:32 PM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
wrote:
> On Tue, Oct 3, 2017 at 12:23 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Oct 2, 2017 at 11:56 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>> wrote:
>>> On Mon, Oct 2, 2017 at 11:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> Whenbo, do you build your PETSc?
>>>> Yes.
>>> My configure option is listed below
>>> ./configure --with-mpi=1 --with-shared-libraries=1 \
>>> --with-64-bit-indices=1 --with-debugging=1
>>> And I set PETSC_DIR, PETSC_ARCH and SLEPC_DIR in my ~/.bashrc.
>>> The Makefile for my problem is listed below,
>>> PETSC_ARCH = arch-linux2-c-debug
>>> PETSC_DIR = /home/zhaowenbo/research/petsc/petsc_git
>>> SLEPC_DIR = /home/zhaowenbo/research/slepc/slepc_git
>>> #PETSC_DIR = /home/zhaowenbo/research/petsc/petsc-3.7.4
>>> #SLEPC_DIR = /home/zhaowenbo/research/slepc/slepc-3.7.3
>>> HYPRE_DIR = /usr/local/hypre
>>> DEBUG_OPT = -g
>>> COMP_FLAGS = -fPIC -Wall \
>>> -I${SLEPC_DIR}/include -I${SLEPC_DIR}/${PETSC_ARCH}/include \
>>> -I${PETSC_DIR}/include -I${PETSC_DIR}/${PETSC_ARCH}/include \
>>> -Isrc
>>> LINK_FLAGS = -fPIC -Wall \
>>> -Wl,-rpath,${SLEPC_DIR}/${PETSC_ARCH}/lib
>>> -L${SLEPC_DIR}/${PETSC_ARCH}/lib -lslepc \
>>> -Wl,-rpath,${PETSC_DIR}/${PETSC_ARCH}/lib
>>> -L${PETSC_DIR}/${PETSC_ARCH}/lib -lpetsc \
>>> -llapack -lblas -lhwloc -lm -lgfortran -lquadmath
>>> step-41: src/main.o src/readinp.o src/base.o src/sp3.o src/diffu.o
>>> mpicxx -o step-41 $^ ${LINK_FLAGS} ${DEBUG_OPT}
>>> src/main.o: src/main.c
>>> mpicxx -o src/main.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>>> src/readinp.o: src/readinp.c
>>> mpicxx -o src/readinp.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>>> src/sp3.o: src/sp3.c
>>> mpicxx -o src/sp3.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>>> src/diffu.o: src/diffu.c
>>> mpicxx -o src/diffu.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>>> src/base.o: src/base.c
>>> mpicxx -o src/base.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>>> clean:
>>> rm step-41 src/main.o src/readinp.o src/sp3.o src/diffu.o src/base.o
>>> runkr_smooth:
>>> mpirun -n ${NCORE} ./step-41 \
>>> -st_ksp_type gmres -st_ksp_view -st_ksp_monitor \
>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
>>> -mata AMAT.dat -matb BMAT.dat \
>>> -st_gamg_est_ksp_view -st_gamg_est_ksp_monitor \
>>> -st_gamg_est_ksp_converged_reason \
>> Add -st_gamg_est_ksp_error_if_not_converged 0
>> Thanks,
>> Matt
> It works after adding -st_gamg_est_ksp_error_if_not_converged 0.
> Thanks,
> Wenbo
>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_smooth 2>&1
>>> runkr_nonsmooth:
>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
>>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_nonsmooth 2>&1
>>> Thanks,
>>> Wenbo
>>>> On Mon, Oct 2, 2017 at 11:45 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> This is normal:
>>>>> Linear st_gamg_est_ solve did not converge due to DIVERGED_ITS
>>>>> iterations 10
>>>>> It looks like ksp->errorifnotconverged got set somehow. If the
>>>>> default changed in KSP then (SAGG) GAMG would not ever work.
>>>>> I assume you don't have a .petscrc file with more (crazy) options in
>>>>> it ...
>>>>> On Mon, Oct 2, 2017 at 11:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Oct 2, 2017 at 11:30 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Mon, Oct 2, 2017 at 11:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> non-smoothed aggregation is converging very fast. smoothed fails in
>>>>>>>> the eigen estimator.
>>>>>>>> Run this again with -st_gamg_est_ksp_view and
>>>>>>>> -st_gamg_est_ksp_monitor, and see if you get more output (I'm not 100% sure
>>>>>>>> about these args).
>>>>>>> I also want -st_gamg_est_ksp_converged_reason
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>> $make NCORE=1 runkr_smooth
>>>>>> mpirun -n 1 ./step-41 \
>>>>>> makefile:43: recipe for target 'runkr_smooth' failed
>>>>>> make: *** [runkr_smooth] Error 91
>>>>>> Thanks
>>>>>> Wenbo
>>>>>>>> On Mon, Oct 2, 2017 at 11:06 AM, Wenbo Zhao <
>>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>>> Matt,
>>>>>>>>> Test 1 nonsmooth
>>>>>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1
>>>>>>>>> runkr_nonsmooth
>>>>>>>>> 0 \
>>>>>>>>> 2>&1
>>>>>>>>> Test 2 smooth
>>>>>>>>> runkr_smooth
>>>>>>>>> 1 \
>>>>>>>>> Thanks,
>>>>>>>>> Wenbo
>>>>>>>>> On Mon, Oct 2, 2017 at 10:48 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <
>>>>>>>>>>> Mark,
>>>>>>>>>>> Thanks for your reply.
>>>>>>>>>>> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Please send the output with -st_ksp_view and -st_ksp_monitor
>>>>>>>>>>>> and we can start to debug it.
>>>>>>>>>>>> Test 1 with nonsmooth and preonly is OK
>>>>>>>>>>> runkr_nonsmooth
>>>>>>>>>>> -st_ksp_view -mata AMAT.dat -matb BMAT.dat \
>>>>>>>>>>> -st_mg_coarse_ksp_type preonly -st_mg_coarse_ksp_monitor \
>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>> Test 2 smooth and preonly is not OK
>>>>>>>>>>> runkr_smooth
>>>>>>>>>>> 2>&1
>>>>>>>>>>> Test 3 nonsmooth and gmres is not OK
>>>>>>>>>>> runkr_gmres
>>>>>>>>>>> -st_mg_coarse_ksp_type gmres -st_mg_coarse_ksp_monitor
>>>>>>>>>>> -st_mg_coarse_ksp_rtol 1.0e-6 \
>>>>>>>>>> DO NOT DO THIS. Please send the output where you do NOTHING to
>>>>>>>>>> the coarse solver.
>>>>>>>>>> Thanks,
>>>>>>>>>> Matt
>>>>>>>>>>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_gmres
>>>>>>>>>>> 2>&1
>>>>>>>>>>> makefile:59: recipe for target 'runkr_gmres' failed
>>>>>>>>>>> make: *** [runkr_gmres] Error 91
>>>>>>>>>>> log-files is attached.
>>>>>>>>>>> You mentioned that B is not symmetric. I assume it is elliptic
>>>>>>>>>>>> (diffusion). Where does the asymmetry come from?
>>>>>>>>>>> It is a two-group diffusion equations, where group denotes
>>>>>>>>>>> neutron enegry discretisation.
>>>>>>>>>>> Matrix B consists of neutron diffusion/leakage term, removal
>>>>>>>>>>> term and minus neutron scatter source term between different energies, when
>>>>>>>>>>> matrix A denotes neutron fission source.
>>>>>>>>>>> Diffusion term(Laplace operator) is elliptic and symmetric.
>>>>>>>>>>> Removal term is diagonal only. However scatter term is asymmetry since
>>>>>>>>>>> scatter term from high energy to low energy is far greater than the term
>>>>>>>>>>> from low to high.
>>>>>>>>>>> Wenbo
>>>>>>>>>>>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <
>>>>>>>>>>>>> Matt,
>>>>>>>>>>>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>>>>>>>>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>>>>>>>>>>>> to test those options.
>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <
>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>> Because I am not clear about what will happen using
>>>>>>>>>>>>>>> 'preonly' for large scale problem.
>>>>>>>>>>>>>> The size of the problem has nothing to do with 'preonly'. All
>>>>>>>>>>>>>> it means is to apply a preconditioner without a Krylov solver.
>>>>>>>>>>>>>>> It seems to use a direct solver from below,
>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>>>>>>>>>>>> KSP/KSPPREONLY.html
>>>>>>>>>>>>>> However, I still cannot understand why you would change the
>>>>>>>>>>>>>> default?
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <
>>>>>>>>>>>>>>>>> Matt,
>>>>>>>>>>>>>>>>> It DOES make no sense for this problem.
>>>>>>>>>>>>>>>>> But I am not clear about the 'preonly' option. Which
>>>>>>>>>>>>>>>>> solver is used in preonly? I wonder if 'preonly' is suitable for large
>>>>>>>>>>>>>>>>> scale problem such as 400,000,000 unknowns.
>>>>>>>>>>>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>>>>>>>>>>>> I mean, why are you setting this at all. Just do not set
>>>>>>>>>>>>>>>> the coarse solver. The default should work fine.
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>> Could you give me some suggestions?
>>>>>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve
>>>>>>>>>>>>>>>>>>> two-group neutron diffusion equations with finite difference method. The
>>>>>>>>>>>>>>>>>>> grid is 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>>>>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where
>>>>>>>>>>>>>>>>>>> B is diagonally dominant matrix but not symmetry.
>>>>>>>>>>>>>>>>>>> EPS is set as below,
>>>>>>>>>>>>>>>>>>> ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>>>>>> ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>>>>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>>>>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only
>>>>>>>>>>>>>>>>>>> non-smooths and preonly is OK.
>>>>>>>>>>>>>>>>>> Why are you setting the coarse solver. This makes no
>>>>>>>>>>>>>>>>>> sense.
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>> Test 1
>>>>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_nonsmooth
>>>>>>>>>>>>>>>>>>> -st_ksp_type gmres \
>>>>>>>>>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>>>>>>>>>> Test 2
>>>>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_smooth
>>>>>>>>>>>>>>>>>>> log_smooth 2>&1
>>>>>>>>>>>>>>>>>>> Test 3
>>>>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_gmres
>>>>>>>>>>>>>>>>>>> -st_mg_coarse_ksp_monitor -st_mg_coarse_ksp_rtol 1.0e-6 \
>>>>>>>>>>>>>>>>>>> log_gmres 2>&1
>>>>>>>>>>>>>>>>>>> Log files were attched.
>>>>>>>>>>>>>>>>>>> The matrix file were also attched as AMAT.dat and
>>>>>>>>>>>>>>>>>>> BMAT.dat.
>>>>>>>>>>>>>>>>>>> Is it correct? Or something wrong with my code or
>>>>>>>>>>>>>>>>>>> commad-line?
>>>>>>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/7e055b23/attachment-0001.html>
