[petsc-users] Issue of mg_coarse_ksp not converge
Wenbo Zhao
zhaowenbo.npic at gmail.com
Mon Oct 2 11:32:42 CDT 2017
On Tue, Oct 3, 2017 at 12:23 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 2, 2017 at 11:56 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
> wrote:
>> On Mon, Oct 2, 2017 at 11:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Whenbo, do you build your PETSc?
>>> Yes.
>> My configure option is listed below
>> ./configure --with-mpi=1 --with-shared-libraries=1 \
>> --with-64-bit-indices=1 --with-debugging=1
>> And I set PETSC_DIR, PETSC_ARCH and SLEPC_DIR in my ~/.bashrc.
>> The Makefile for my problem is listed below,
>> PETSC_ARCH = arch-linux2-c-debug
>> PETSC_DIR = /home/zhaowenbo/research/petsc/petsc_git
>> SLEPC_DIR = /home/zhaowenbo/research/slepc/slepc_git
>> #PETSC_DIR = /home/zhaowenbo/research/petsc/petsc-3.7.4
>> #SLEPC_DIR = /home/zhaowenbo/research/slepc/slepc-3.7.3
>> HYPRE_DIR = /usr/local/hypre
>> DEBUG_OPT = -g
>> COMP_FLAGS = -fPIC -Wall \
>> -I${SLEPC_DIR}/include -I${SLEPC_DIR}/${PETSC_ARCH}/include \
>> -I${PETSC_DIR}/include -I${PETSC_DIR}/${PETSC_ARCH}/include \
>> -Isrc
>> LINK_FLAGS = -fPIC -Wall \
>> -Wl,-rpath,${SLEPC_DIR}/${PETSC_ARCH}/lib
>> -L${SLEPC_DIR}/${PETSC_ARCH}/lib -lslepc \
>> -Wl,-rpath,${PETSC_DIR}/${PETSC_ARCH}/lib
>> -L${PETSC_DIR}/${PETSC_ARCH}/lib -lpetsc \
>> -llapack -lblas -lhwloc -lm -lgfortran -lquadmath
>> step-41: src/main.o src/readinp.o src/base.o src/sp3.o src/diffu.o
>> mpicxx -o step-41 $^ ${LINK_FLAGS} ${DEBUG_OPT}
>> src/main.o: src/main.c
>> mpicxx -o src/main.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>> src/readinp.o: src/readinp.c
>> mpicxx -o src/readinp.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>> src/sp3.o: src/sp3.c
>> mpicxx -o src/sp3.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>> src/diffu.o: src/diffu.c
>> mpicxx -o src/diffu.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>> src/base.o: src/base.c
>> mpicxx -o src/base.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
>> clean:
>> rm step-41 src/main.o src/readinp.o src/sp3.o src/diffu.o src/base.o
>> runkr_smooth:
>> mpirun -n ${NCORE} ./step-41 \
>> -st_ksp_type gmres -st_ksp_view -st_ksp_monitor \
>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
>> -mata AMAT.dat -matb BMAT.dat \
>> -st_gamg_est_ksp_view -st_gamg_est_ksp_monitor \
>> -st_gamg_est_ksp_converged_reason \
> Add -st_gamg_est_ksp_error_if_not_converged 0
> Thanks,
> Matt
It works after adding -st_gamg_est_ksp_error_if_not_converged 0.
Wenbo
> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_smooth 2>&1
>> runkr_nonsmooth:
>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_nonsmooth 2>&1
>> Thanks,
>> Wenbo
>>> On Mon, Oct 2, 2017 at 11:45 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> This is normal:
>>>> Linear st_gamg_est_ solve did not converge due to DIVERGED_ITS
>>>> iterations 10
>>>> It looks like ksp->errorifnotconverged got set somehow. If the default
>>>> changed in KSP then (SAGG) GAMG would not ever work.
>>>> I assume you don't have a .petscrc file with more (crazy) options in it
>>>> On Mon, Oct 2, 2017 at 11:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>> wrote:
>>>>> On Mon, Oct 2, 2017 at 11:30 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Oct 2, 2017 at 11:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> non-smoothed aggregation is converging very fast. smoothed fails in
>>>>>>> the eigen estimator.
>>>>>>> Run this again with -st_gamg_est_ksp_view and
>>>>>>> -st_gamg_est_ksp_monitor, and see if you get more output (I'm not 100% sure
>>>>>>> about these args).
>>>>>> I also want -st_gamg_est_ksp_converged_reason
>>>>>> Thanks,
>>>>>> Matt
>>>>> $make NCORE=1 runkr_smooth
>>>>> mpirun -n 1 ./step-41 \
>>>>> makefile:43: recipe for target 'runkr_smooth' failed
>>>>> make: *** [runkr_smooth] Error 91
>>>>> Thanks
>>>>> Wenbo
>>>>>>> On Mon, Oct 2, 2017 at 11:06 AM, Wenbo Zhao <
>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>> Matt,
>>>>>>>> Test 1 nonsmooth
>>>>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1
>>>>>>>> runkr_nonsmooth
>>>>>>>> 2>&1
>>>>>>>> Test 2 smooth
>>>>>>>> runkr_smooth
>>>>>>>> Thanks,
>>>>>>>> Wenbo
>>>>>>>> On Mon, Oct 2, 2017 at 10:48 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <
>>>>>>>>>> Mark,
>>>>>>>>>> Thanks for your reply.
>>>>>>>>>> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>>> Please send the output with -st_ksp_view and -st_ksp_monitor and
>>>>>>>>>>> we can start to debug it.
>>>>>>>>>>> Test 1 with nonsmooth and preonly is OK
>>>>>>>>>> runkr_nonsmooth
>>>>>>>>>> 0 \
>>>>>>>>>> -st_ksp_view -mata AMAT.dat -matb BMAT.dat \
>>>>>>>>>> -st_mg_coarse_ksp_type preonly -st_mg_coarse_ksp_monitor \
>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>> Test 2 smooth and preonly is not OK
>>>>>>>>>> runkr_smooth
>>>>>>>>>> 1 \
>>>>>>>>>> 2>&1
>>>>>>>>>> Test 3 nonsmooth and gmres is not OK
>>>>>>>>>> runkr_gmres
>>>>>>>>>> 0 \
>>>>>>>>>> -st_mg_coarse_ksp_type gmres -st_mg_coarse_ksp_monitor
>>>>>>>>>> -st_mg_coarse_ksp_rtol 1.0e-6 \
>>>>>>>>> DO NOT DO THIS. Please send the output where you do NOTHING to the
>>>>>>>>> coarse solver.
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_gmres
>>>>>>>>>> 2>&1
>>>>>>>>>> makefile:59: recipe for target 'runkr_gmres' failed
>>>>>>>>>> make: *** [runkr_gmres] Error 91
>>>>>>>>>> log-files is attached.
>>>>>>>>>> You mentioned that B is not symmetric. I assume it is elliptic
>>>>>>>>>>> (diffusion). Where does the asymmetry come from?
>>>>>>>>>> It is a two-group diffusion equations, where group denotes
>>>>>>>>>> neutron enegry discretisation.
>>>>>>>>>> Matrix B consists of neutron diffusion/leakage term, removal term
>>>>>>>>>> and minus neutron scatter source term between different energies, when
>>>>>>>>>> matrix A denotes neutron fission source.
>>>>>>>>>> Diffusion term(Laplace operator) is elliptic and symmetric.
>>>>>>>>>> Removal term is diagonal only. However scatter term is asymmetry since
>>>>>>>>>> scatter term from high energy to low energy is far greater than the term
>>>>>>>>>> from low to high.
>>>>>>>>>> Wenbo
>>>>>>>>>>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <
>>>>>>>>>>>> Matt,
>>>>>>>>>>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>>>>>>>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>>>>>>>>>>> to test those options.
>>>>>>>>>>>> Wenbo
>>>>>>>>>>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <
>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>> Because I am not clear about what will happen using 'preonly'
>>>>>>>>>>>>>> for large scale problem.
>>>>>>>>>>>>> The size of the problem has nothing to do with 'preonly'. All
>>>>>>>>>>>>> it means is to apply a preconditioner without a Krylov solver.
>>>>>>>>>>>>>> It seems to use a direct solver from below,
>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>>>>>>>>>>> KSP/KSPPREONLY.html
>>>>>>>>>>>>> However, I still cannot understand why you would change the
>>>>>>>>>>>>> default?
>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <
>>>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <
>>>>>>>>>>>>>>>> Matt,
>>>>>>>>>>>>>>>> It DOES make no sense for this problem.
>>>>>>>>>>>>>>>> But I am not clear about the 'preonly' option. Which solver
>>>>>>>>>>>>>>>> is used in preonly? I wonder if 'preonly' is suitable for large scale
>>>>>>>>>>>>>>>> problem such as 400,000,000 unknowns.
>>>>>>>>>>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>>>>>>>>>>> I mean, why are you setting this at all. Just do not set the
>>>>>>>>>>>>>>> coarse solver. The default should work fine.
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>> Could you give me some suggestions?
>>>>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve
>>>>>>>>>>>>>>>>>> two-group neutron diffusion equations with finite difference method. The
>>>>>>>>>>>>>>>>>> grid is 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>>>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where
>>>>>>>>>>>>>>>>>> B is diagonally dominant matrix but not symmetry.
>>>>>>>>>>>>>>>>>> EPS is set as below,
>>>>>>>>>>>>>>>>>> ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>>>>> ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>>>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>>>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only
>>>>>>>>>>>>>>>>>> non-smooths and preonly is OK.
>>>>>>>>>>>>>>>>> Why are you setting the coarse solver. This makes no sense.
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>> Test 1
>>>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_nonsmooth
>>>>>>>>>>>>>>>>>> -st_ksp_type gmres \
>>>>>>>>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>>>>>>>>> Test 2
>>>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_smooth
>>>>>>>>>>>>>>>>>> log_smooth 2>&1
>>>>>>>>>>>>>>>>>> Test 3
>>>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_gmres
>>>>>>>>>>>>>>>>>> -st_mg_coarse_ksp_monitor -st_mg_coarse_ksp_rtol 1.0e-6 \
>>>>>>>>>>>>>>>>>> log_gmres 2>&1
>>>>>>>>>>>>>>>>>> Log files were attched.
>>>>>>>>>>>>>>>>>> The matrix file were also attched as AMAT.dat and
>>>>>>>>>>>>>>>>>> BMAT.dat.
>>>>>>>>>>>>>>>>>> Is it correct? Or something wrong with my code or
>>>>>>>>>>>>>>>>>> commad-line?
>>>>>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171003/59ea039d/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171003/59ea039d/attachment-0001.tgz>
