[petsc-users] Load distributed matrices from directory
Mon Oct 2 04:34:21 CDT 2017
On Mon, Oct 2, 2017 at 4:12 AM, Matthieu Vitse <vitse at lmt.ens-cachan.fr>
wrote:
> Le 29 sept. 2017 à 17:43, Barry Smith <bsmith at mcs.anl.gov> a écrit :
>  Or is your matrix generator code sequential and cannot generate the full
> matrix so you want to generate chunks at a time and save to disk then load
> them? Better for you to refactor your code to work in parallel in
> generating the whole thing (since you can already generate parts the
> refactoring shouldn't be terribly difficult).
> Thanks for your answer.
> The matrix is already generated in parallel, but we want to keep control
> on the decomposition which conflicts with directly using PCASM.
Please explain this statement with an example. When using MatLoad(), you
are in control of the partitions, although not of the row order.
Also, I am confused by your use of the word "distributed". We use it to
mean an object, like a Mat that exists on several processes in a
coordinated way.
    Matt
> That’s why we would really like to work only with the distributed
> matrices. Are there some issues that would prevent me from doing that ?
> Moreover, ASM is a first step, we would like then to use those matrices for
> multi-preconditioning our problem, and take into account MPCs (as a
> consequence we really need to know the decomposition).
> Thanks,
>> Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/8ae53915/attachment.html>
