[petsc-users] 2 Dirichlet conditions for one Element in PetscFE
Yann Jobic
yann.jobic at univ-amu.fr
Fri Nov 24 04:34:13 CST 2017
Le 23/11/2017 à 13:45, Matthew Knepley a écrit :
> On Thu, Nov 23, 2017 at 3:39 AM, Yann Jobic <yann.jobic at univ-amu.fr
> <mailto:yann.jobic at univ-amu.fr>> wrote:
> Hello,
> I checked out the branch knepley/fix-plex-bc-multiple, but i now
> have a strange problem.
> I splited my labels as in ex69.c of snes. It may be the right way
> to do it.
> In petsc 3.8.2, i have the same behavior as before, the element
> containing the face is called by PetscDSAddBoundary.
> In the git version, PetscDSAddBoundary does not call my boundary
> function at all.
> The call :
> ierr = PetscDSAddBoundary(prob, DM_BC_ESSENTIAL, "wallL",
> "markerLeft", 0, Ncomp, components, (void (*)(void)) uIn, 1,
> &id, ctx);CHKERRQ(ierr);
> I checked that my labels are correct :
> markerLeft: 1 strata with value/size (1 (11))
> markerTop: 1 strata with value/size (1 (11))
> markerRight: 1 strata with value/size (1 (11))
> markerBottom: 1 strata with value/size (1 (11))
> What am i doing wrong ?
> So you call AddBoundary() and then the boundary values are never
> inserted? The call looks correct. Can you send me an example to check?
> Obviously this works for my simple examples in the repo. I can't see
> by looking what might be wrong for you.
Hello,
I may have the wrong git directory.
I've got the message when i'm compiling :
The version of PETSc you are using is out-of-date, we recommend updating
to the new release
Available Version: 3.8.2 Installed Version: 3.8
As i'm not familiar with git, I've done :
git clone https://bitbucket.org/petsc/petsc
git checkout knepley/fix-plex-bc-multiple
With this petsc version, ex46 and ex47 are not working (from TS), and
after calling PetscDSAddBoundary, it seems that the boundary values are
never inserted, as in my own code.
Do i have the right petsc development version ?
Yann
PS : In my old code, i've tried to mix ex56 and ex69 for marking
boundary values.
I first set labels for "Faces", and using this label, i create new
separated ones (North, South, ...).
It worked in sequential, but in parallel, the program hang at
DMPlexCreateClosureIndex.
So i just kept "Faces", as in ex56, and it worked in parallel.
> Thanks,
> Matt
> Thanks,
> Regards,
> Yann
> Le 22/11/2017 à 18:51, Matthew Knepley a écrit :
>> On Wed, Nov 22, 2017 at 12:39 PM, Yann Jobic
>> <yann.jobic at univ-amu.fr <mailto:yann.jobic at univ-amu.fr>> wrote:
>> Hello,
>> I've found a strange behavior when looking into a bug for the
>> pressure convergence of a simple Navier-Stokes problem using
>> PetscFE.
>> I followed many examples for labeling boundary faces. I first
>> use DMPlexMarkBoundaryFaces, (label=1 to the faces).
>> I find those faces using DMGetStratumIS and searching 1 as it
>> is the value of the marked boundary faces.
>> Finally i use DMPlexLabelComplete over the new label.
>> I then use :
>> ierr = PetscDSAddBoundary(prob, DM_BC_ESSENTIAL, "in",
>> "Faces", 0, Ncomp, components, (void (*)(void)) uIn, NWest,
>> west, NULL);CHKERRQ(ierr);
>> in order to impose a dirichlet condition for the faces
>> labeled by the correct value (west=1, south=3,...).
>> However, the function "uIn()" is called in all the Elements
>> containing the boundary faces, and thus impose the values at
>> nodes that are not in the labeled faces.
>> Is it a normal behavior ? I then have to test the position of
>> the node calling uIn, in order to impose the good value.
>> I have this problem for a Poiseuille flow, where at 2 corner
>> Elements i have a zero velocity dirichlet condition (wall)
>> and a In flow velocity one.
>> I believe I have fixed this in knepley/fix-plex-bc-multiple which
>> should be merged soon. Do you know how to merge that branch and try?
>> Thanks,
>> Matt
>> The pressure is then very high at the corner nodes of those 2
>> Elements.
>> Do you think my pressure problem comes from there ? (The
>> velocity field is correct)
>> Many thanks,
>> Regards,
>> Yann
>> PS : i'm using those runtime options :
>> -vel_petscspace_order 2 -pres_petscspace_order 1 \
>> -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type
>> schur -pc_fieldsplit_schur_fact_type full \
>> -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_ksp_rtol
>> 1.0e-10 -fieldsplit_pressure_pc_type jacobi
>> L'absence de virus dans ce courrier électronique a été
>> vérifiée par le logiciel antivirus Avast.
>> https://www.avast.com/antivirus <https://www.avast.com/antivirus>
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.caam.rice.edu/%7Emk51/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171124/547b159e/attachment.html>
