[petsc-users] DMPlexCreateFromDAG and orientation
Matthew Knepley
knepley at gmail.com
Mon Nov 20 07:47:02 CST 2017
On Sun, Nov 19, 2017 at 4:59 PM, Yann Jobic <yann.jobic at univ-amu.fr> wrote:
> Hello,
> I want to create my custom DMPLEX by using DMPlexCreateFromDAG(). I tried
> with only one cell. I have :
It looks like a hex cell. Here is how I order hex cells:
https://bitbucket.org/petsc/petsc/src/d89bd21cf2b5366df29efb6006298d2bc22fb509/src/dm/impls/plex/plexinterpolate.c?at=master&fileviewer=file-view-default#plexinterpolate.c-113
The first four vertices are on the bottom, last four on the top. Those
faces start with vertices right above each other, and
the faces have outward orientation. You can check your structure by looking
at the faces specified above, and see if it
matches yours, with outward orientation for all.
Eventually me, or someone, will draw pictures of these for the manual.
Matt
> type: plex
> Mesh 'DM_0x3dd7df0_0':
> orientation is missing
> cap --> base:
> [0] Max sizes cone: 8 support: 1
> [0]: 1 ----> 0
> [0]: 2 ----> 0
> [0]: 3 ----> 0
> [0]: 4 ----> 0
> [0]: 5 ----> 0
> [0]: 6 ----> 0
> [0]: 7 ----> 0
> [0]: 8 ----> 0
> base <-- cap:
> [0]: 0 <---- 1 (0)
> [0]: 0 <---- 5 (0)
> [0]: 0 <---- 7 (0)
> [0]: 0 <---- 3 (0)
> [0]: 0 <---- 2 (0)
> [0]: 0 <---- 6 (0)
> [0]: 0 <---- 8 (0)
> [0]: 0 <---- 4 (0)
> coordinates with 1 fields
> field 0 with 3 components
> Process 0:
> ( 1) dim 3 offset 0 0. 0. 0.
> ( 2) dim 3 offset 3 0. 0. 0.01
> ( 3) dim 3 offset 6 0. 0.01 0.
> ( 4) dim 3 offset 9 0. 0.01 0.01
> ( 5) dim 3 offset 12 0.01 0. 0.
> ( 6) dim 3 offset 15 0.01 0. 0.01
> ( 7) dim 3 offset 18 0.01 0.01 0.
> ( 8) dim 3 offset 21 0.01 0.01 0.01
> Which is not correct when i'm trying to see the DM in visit. I tried one
> from the example ex4.c, which gives :
> base <-- cap:
> [0]: 0 <---- 1 (0)
> [0]: 0 <---- 2 (0)
> [0]: 0 <---- 3 (0)
> [0]: 0 <---- 4 (0)
> [0]: 0 <---- 5 (0)
> [0]: 0 <---- 6 (0)
> [0]: 0 <---- 7 (0)
> [0]: 0 <---- 8 (0)
> Process 0:
> ( 1) dim 3 offset 0 -1. -1. -1.
> ( 2) dim 3 offset 3 -1. 1. -1.
> ( 3) dim 3 offset 6 1. 1. -1.
> ( 4) dim 3 offset 9 1. -1. -1.
> ( 5) dim 3 offset 12 -1. -1. 1.
> ( 6) dim 3 offset 15 1. -1. 1.
> ( 7) dim 3 offset 18 1. 1. 1.
> ( 8) dim 3 offset 21 -1. 1. 1.
> And this one is perfect.
> I may have a problem with the "cone orientation", but i really don't
> understand how to set it. I tried the use DMPlexOrient(), but i still have
> the problem.
> However, my connectivity looks good. What i am doing wrong ? This is even
> more complicated when i have two cells sharing a face.
> Thanks for the help !
> Regards,
> Yann
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171120/7ce1c862/attachment.html>
