[petsc-users] DMPlexCreateFromDAG and orientation
Yann Jobic
yann.jobic at univ-amu.fr
Sun Nov 19 15:59:00 CST 2017
Hello,
I want to create my custom DMPLEX by using DMPlexCreateFromDAG(). I
tried with only one cell. I have :
type: plex
Mesh 'DM_0x3dd7df0_0':
orientation is missing
cap --> base:
[0] Max sizes cone: 8 support: 1
[0]: 1 ----> 0
[0]: 2 ----> 0
[0]: 3 ----> 0
[0]: 4 ----> 0
[0]: 5 ----> 0
[0]: 6 ----> 0
[0]: 7 ----> 0
[0]: 8 ----> 0
base <-- cap:
[0]: 0 <---- 1 (0)
[0]: 0 <---- 5 (0)
[0]: 0 <---- 7 (0)
[0]: 0 <---- 3 (0)
[0]: 0 <---- 2 (0)
[0]: 0 <---- 6 (0)
[0]: 0 <---- 8 (0)
[0]: 0 <---- 4 (0)
coordinates with 1 fields
field 0 with 3 components
Process 0:
( 1) dim 3 offset 0 0. 0. 0.
( 2) dim 3 offset 3 0. 0. 0.01
( 3) dim 3 offset 6 0. 0.01 0.
( 4) dim 3 offset 9 0. 0.01 0.01
( 5) dim 3 offset 12 0.01 0. 0.
( 6) dim 3 offset 15 0.01 0. 0.01
( 7) dim 3 offset 18 0.01 0.01 0.
( 8) dim 3 offset 21 0.01 0.01 0.01
Which is not correct when i'm trying to see the DM in visit. I tried one
from the example ex4.c, which gives :
base <-- cap:
[0]: 0 <---- 1 (0)
[0]: 0 <---- 2 (0)
[0]: 0 <---- 3 (0)
[0]: 0 <---- 4 (0)
[0]: 0 <---- 5 (0)
[0]: 0 <---- 6 (0)
[0]: 0 <---- 7 (0)
[0]: 0 <---- 8 (0)
Process 0:
( 1) dim 3 offset 0 -1. -1. -1.
( 2) dim 3 offset 3 -1. 1. -1.
( 3) dim 3 offset 6 1. 1. -1.
( 4) dim 3 offset 9 1. -1. -1.
( 5) dim 3 offset 12 -1. -1. 1.
( 6) dim 3 offset 15 1. -1. 1.
( 7) dim 3 offset 18 1. 1. 1.
( 8) dim 3 offset 21 -1. 1. 1.
And this one is perfect.
I may have a problem with the "cone orientation", but i really don't
understand how to set it. I tried the use DMPlexOrient(), but i still
have the problem.
However, my connectivity looks good. What i am doing wrong ? This is
even more complicated when i have two cells sharing a face.
Thanks for the help !
Yann
