[petsc-users] superlu_dist produces random results
Smith, Barry F.
bsmith at mcs.anl.gov
Wed Nov 15 15:52:18 CST 2017
> On Nov 15, 2017, at 3:36 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> Hi Barry,
> Thanks for your reply. I was wondering why this happens only when we use superlu_dist. I am trying to understand the algorithm in superlu_dist. If we use ASM or MUMPS, we do not produce these differences.
> The differences actually are NOT meaningless. In fact, we have a real transient application that presents this issue. When we run the simulation with superlu_dist in parallel for thousands of time steps, the final physics solution looks totally different from different runs. The differences are not acceptable any more. For a steady problem, the difference may be meaningless. But it is significant for the transient problem.
I submit that the "physics solution" of all of these runs is equally right and equally wrong. If the solutions are very different due to a small perturbation than something is wrong with the model or the integrator, I don't think you can blame the linear solver (see below)
> This makes the solution not reproducible, and we can not even set a targeting solution in the test system because the solution is so different from one run to another. I guess there might/may be a tiny bug in superlu_dist or the PETSc interface to superlu_dist.
This is possible but it is also possible this is due to normal round off inside of SuperLU dist.
Since you have SuperLU_Dist inside a nonlinear iteration it shouldn't really matter exactly how well SuperLU_Dist does. The nonlinear iteration does essential defect correction for you; are you making sure that the nonlinear iteration always works for every timestep? For example confirm that SNESGetConvergedReason() is always positive.
> Fande,
> On Wed, Nov 15, 2017 at 1:59 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Meaningless differences
> > On Nov 15, 2017, at 2:26 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Hi,
> > There is a heat conduction problem. When superlu_dist is used as a preconditioner, we have random results from different runs. Is there a random algorithm in superlu_dist? If we use ASM or MUMPS as the preconditioner, we then don't have this issue.
> > run 1:
> > 0 Nonlinear |R| = 9.447423e+03
> > 0 Linear |R| = 9.447423e+03
> > 1 Linear |R| = 1.013384e-02
> > 2 Linear |R| = 4.020995e-08
> > 1 Nonlinear |R| = 1.404678e-02
> > 0 Linear |R| = 1.404678e-02
> > 1 Linear |R| = 5.104757e-08
> > 2 Linear |R| = 7.699637e-14
> > 2 Nonlinear |R| = 5.106418e-08
> > run 2:
> > 1 Linear |R| = 5.109913e-08
> > 2 Linear |R| = 7.189091e-14
> > 2 Nonlinear |R| = 5.111591e-08
> > run 3:
> > 1 Linear |R| = 5.104942e-08
> > 2 Linear |R| = 7.465572e-14
> > 2 Nonlinear |R| = 5.106642e-08
> > run 4:
> > 1 Linear |R| = 5.102730e-08
> > 2 Linear |R| = 7.132220e-14
> > 2 Nonlinear |R| = 5.104442e-08
> > Solver details:
> > SNES Object: 8 MPI processes
> > type: newtonls
> > maximum iterations=15, maximum function evaluations=10000
> > tolerances: relative=1e-08, absolute=1e-11, solution=1e-50
> > total number of linear solver iterations=4
> > total number of function evaluations=7
> > norm schedule ALWAYS
> > SNESLineSearch Object: 8 MPI processes
> > type: basic
> > maxstep=1.000000e+08, minlambda=1.000000e-12
> > tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
> > maximum iterations=40
> > KSP Object: 8 MPI processes
> > type: gmres
> > restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> > happy breakdown tolerance 1e-30
> > maximum iterations=100, initial guess is zero
> > tolerances: relative=1e-06, absolute=1e-50, divergence=10000.
> > right preconditioning
> > using UNPRECONDITIONED norm type for convergence test
> > PC Object: 8 MPI processes
> > type: lu
> > out-of-place factorization
> > tolerance for zero pivot 2.22045e-14
> > matrix ordering: natural
> > factor fill ratio given 0., needed 0.
> > Factored matrix follows:
> > Mat Object: 8 MPI processes
> > type: superlu_dist
> > rows=7925, cols=7925
> > package used to perform factorization: superlu_dist
> > total: nonzeros=0, allocated nonzeros=0
> > total number of mallocs used during MatSetValues calls =0
> > SuperLU_DIST run parameters:
> > Process grid nprow 4 x npcol 2
> > Equilibrate matrix TRUE
> > Matrix input mode 1
> > Replace tiny pivots FALSE
> > Use iterative refinement TRUE
> > Processors in row 4 col partition 2
> > Row permutation LargeDiag
> > Column permutation METIS_AT_PLUS_A
> > Parallel symbolic factorization FALSE
> > Repeated factorization SamePattern
> > linear system matrix followed by preconditioner matrix:
> > type: mffd
> > Matrix-free approximation:
> > err=1.49012e-08 (relative error in function evaluation)
> > Using wp compute h routine
> > Does not compute normU
> > Mat Object: () 8 MPI processes
> > type: mpiaij
> > total: nonzeros=63587, allocated nonzeros=63865
> > not using I-node (on process 0) routines
> > Fande,
