[petsc-users] superlu_dist produces random results
    Matthew Knepley
    knepley at gmail.com
    Wed Nov 15 15:51:31 CST 2017
On Wed, Nov 15, 2017 at 4:36 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> Hi Barry,
> Thanks for your reply. I was wondering why this happens only when we use
> superlu_dist. I am trying to understand the algorithm in superlu_dist. If
> we use ASM or MUMPS, we do not produce these differences.
> The differences actually are NOT meaningless.  In fact, we have a real
> transient application that presents this issue.   When we run the
> simulation with superlu_dist in parallel for thousands of time steps, the
> final physics  solution looks totally different from different runs. The
> differences are not acceptable any more.  For a steady problem, the
> difference may be meaningless. But it is significant for the transient
> problem.
Are you sure this formulation is stable? It does not seem like it.
    Matt
> This makes the solution not reproducible, and we can not even set a
> targeting solution in the test system because the solution is so different
> from one run to another.   I guess there might/may be a tiny bug in
> superlu_dist or the PETSc interface to superlu_dist.
> Fande,
> On Wed, Nov 15, 2017 at 1:59 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>>   Meaningless differences
>> > On Nov 15, 2017, at 2:26 PM, Kong, Fande <fande.kong at inl.gov> wrote:
>> > Hi,
>> > There is a heat conduction problem. When superlu_dist is used as a
>> preconditioner, we have random results from different runs. Is there a
>> random algorithm in superlu_dist? If we use ASM or MUMPS as the
>> preconditioner, we then don't have this issue.
>> > run 1:
>> >  0 Nonlinear |R| = 9.447423e+03
>> >       0 Linear |R| = 9.447423e+03
>> >       1 Linear |R| = 1.013384e-02
>> >       2 Linear |R| = 4.020995e-08
>> >  1 Nonlinear |R| = 1.404678e-02
>> >       0 Linear |R| = 1.404678e-02
>> >       1 Linear |R| = 5.104757e-08
>> >       2 Linear |R| = 7.699637e-14
>> >  2 Nonlinear |R| = 5.106418e-08
>> > run 2:
>> >       1 Linear |R| = 5.109913e-08
>> >       2 Linear |R| = 7.189091e-14
>> >  2 Nonlinear |R| = 5.111591e-08
>> > run 3:
>> >       1 Linear |R| = 5.104942e-08
>> >       2 Linear |R| = 7.465572e-14
>> >  2 Nonlinear |R| = 5.106642e-08
>> > run 4:
>> >       1 Linear |R| = 5.102730e-08
>> >       2 Linear |R| = 7.132220e-14
>> >  2 Nonlinear |R| = 5.104442e-08
>> > Solver details:
>> > SNES Object: 8 MPI processes
>> >   type: newtonls
>> >   maximum iterations=15, maximum function evaluations=10000
>> >   tolerances: relative=1e-08, absolute=1e-11, solution=1e-50
>> >   total number of linear solver iterations=4
>> >   total number of function evaluations=7
>> >   norm schedule ALWAYS
>> >   SNESLineSearch Object: 8 MPI processes
>> >     type: basic
>> >     maxstep=1.000000e+08, minlambda=1.000000e-12
>> >     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>> lambda=1.000000e-08
>> >     maximum iterations=40
>> >   KSP Object: 8 MPI processes
>> >     type: gmres
>> >       restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> >       happy breakdown tolerance 1e-30
>> >     maximum iterations=100, initial guess is zero
>> >     tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
>> >     right preconditioning
>> >     using UNPRECONDITIONED norm type for convergence test
>> >   PC Object: 8 MPI processes
>> >     type: lu
>> >       out-of-place factorization
>> >       tolerance for zero pivot 2.22045e-14
>> >       matrix ordering: natural
>> >       factor fill ratio given 0., needed 0.
>> >         Factored matrix follows:
>> >           Mat Object: 8 MPI processes
>> >             type: superlu_dist
>> >             rows=7925, cols=7925
>> >             package used to perform factorization: superlu_dist
>> >             total: nonzeros=0, allocated nonzeros=0
>> >             total number of mallocs used during MatSetValues calls =0
>> >               SuperLU_DIST run parameters:
>> >                 Process grid nprow 4 x npcol 2
>> >                 Equilibrate matrix TRUE
>> >                 Matrix input mode 1
>> >                 Replace tiny pivots FALSE
>> >                 Use iterative refinement TRUE
>> >                 Processors in row 4 col partition 2
>> >                 Row permutation LargeDiag
>> >                 Column permutation METIS_AT_PLUS_A
>> >                 Parallel symbolic factorization FALSE
>> >                 Repeated factorization SamePattern
>> >     linear system matrix followed by preconditioner matrix:
>> >       type: mffd
>> >         Matrix-free approximation:
>> >           err=1.49012e-08 (relative error in function evaluation)
>> >           Using wp compute h routine
>> >               Does not compute normU
>> >     Mat Object: () 8 MPI processes
>> >       type: mpiaij
>> >       total: nonzeros=63587, allocated nonzeros=63865
>> >         not using I-node (on process 0) routines
>> > Fande,
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171115/c478dce3/attachment.html>
