[petsc-users] indices into Vec/Mat associated to a DMPlex
Wed Nov 15 05:16:04 CST 2017
On Wed, Nov 15, 2017 at 6:09 AM, Matteo Semplice <matteo.semplice at unito.it>
wrote:
> On 15/11/2017 11:39, Matthew Knepley wrote:
> On Wed, Nov 15, 2017 at 3:11 AM, Matteo Semplice <matteo.semplice at unito.it
> > wrote:
>> Hi.
>> I am struggling with indices into matrices associated to a DMPLex mesh. I
>> can explain my problem to the following minimal example.
>> Let's say I want to assemble the matrix to solve an equation (say
>> Laplace) with data attached to cells and the finite volume method. In
>> principle I
>> - loop over the faces of the DMPlex (height=1)
>> - for each face, find neighbouring cells (say points i and j in the
>> DMPlex) and compute the contributions coming from that face (in the example
>> it would be something like (u_j-u_i)*<x_j-x_i,n> with x=centroids, n=scaled
>> normal to face and <,> the inner product)
>> - insert the contributions +/-<x_j-x_i,n> in rows/columns n(i) and n(j)
>> of the matrix where n(k) is the index into Vec/Mat of the unknown
>> associated to the k-th cell
>> My problem is how to find out n(k). I assume that the Section should be
>> able to tell me, but I cannot find the correct function to call. I see that
>> FEM methods can use DMPlexMatSetClosure but here we'd need a
>> DMPlexMatSetCone...
> Everything always reduces to raw Section calls. For instance, for cell c
>   PetscSectionGetDof(sec, c, &dof);
>   PetscSectionGetOffset(sec, c, &off);
> give the number of degrees of freedom on the cell, and the offset into
> storage (a local vector for the local section, and global vector for the
> global section).
> The Closure stuff just calls this for every point in the closure.
> All right, so the offset is also the (global) index and that is to be used
> in calls to MatSetValues.
Not quite. For all owned dofs, it is (in the global section). For all
unowned dofs, it is -(off+1), so you have
to convert it if you want to set off-process values.
    Matt
> Thanks a lot!
>     Matteo
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171115/fc1a9c58/attachment.html>
