[petsc-users] unsorted local columns in 3.8?
Mark Adams mfadams at lbl.gov
Wed Nov 8 11:01:38 CST 2017
On Wed, Nov 8, 2017 at 11:09 AM, Hong <hzhang at mcs.anl.gov> wrote:
> Mark:
>> Hong, is
>> >   0-cells: 12 12 0 0
>> >   1-cells: 20 20 0 0
>> >   2-cells: 11 11 0 0
>> >   3-cells: 2 2 0 0
>> from the old version?
> In O-build on my macPro, I get the above. In g-build, I get
>>   0-cells: 8 8 8 8
>>   1-cells: 12 12 12 12
>>   2-cells: 6 6 6 6
>>   3-cells: 1 1 1 1
> I get this on linux machine.
> Do you know why?
I can not reproduce your O output. I will look at it later.
Valgrind is failing on me right now. I will look into it but can you
valgrind it?
> Hong
>> On Tue, Nov 7, 2017 at 10:13 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>> Mark:
>>> I removed option '-ex56_dm_view'.
>>> Hong
>>> Humm, this looks a little odd, but it may be OK.  Is this this diffing
>>>> with the old non-repartition data? (more below)
>>>> On Tue, Nov 7, 2017 at 11:45 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>> Mark,
>>>>> The fix is merged to next branch for tests which show diff as
>>>>> ******* Testing: testexamples_PARMETIS *******
>>>>> 5c5
>>>>> <   1 SNES Function norm 1.983e-10
>>>>> >   1 SNES Function norm 1.990e-10
>>>>> 10,13c10,13
>>>>> <   0-cells: 8 8 8 8
>>>>> <   1-cells: 12 12 12 12
>>>>> <   2-cells: 6 6 6 6
>>>>> <   3-cells: 1 1 1 1
>>>> I assume this is the old.
>>>>> >   0-cells: 12 12 0 0
>>>>> >   1-cells: 20 20 0 0
>>>>> >   2-cells: 11 11 0 0
>>>>> >   3-cells: 2 2 0 0
>>>>> 15,18c15,18
>>>> and this is the new.
>>>> This is funny because the processors are not fully populated. This can
>>>> happen on coarse grids and indeed it should happen in a test with good
>>>> coverage.
>>>> I assume these diffs are views from coarse grids? That is, in the raw
>>>> output files do you see fully populated fine grids, with no diffs, and then
>>>> the diffs come on coarse grids.
>>>> Repartitioning the coarse grids can change the coarsening, It is
>>>> possible that repartitioning causes faster coarsening (it does a little)
>>>> and this faster coarsening is tripping the aggregation switch, which gives
>>>> us empty processors.
>>>> Am I understanding this correctly ...
>>>> Thanks,
>>>> Mark
>>>>> <   boundary: 1 strata with value/size (1 (23))
>>>>> <   Face Sets: 4 strata with value/size (1 (1), 2 (1), 4 (1), 6 (1))
>>>>> <   marker: 1 strata with value/size (1 (15))
>>>>> <   depth: 4 strata with value/size (0 (8), 1 (12), 2 (6), 3 (1))
>>>>> >   boundary: 1 strata with value/size (1 (39))
>>>>> >   Face Sets: 5 strata with value/size (1 (2), 2 (2), 4 (2), 5 (1), 6 (1))
>>>>> >   marker: 1 strata with value/size (1 (27))
>>>>> >   depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
>>>>> see http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/07/examples_full_next-tmp.log
>>>>> I guess parmetis produces random partition on different machines (I made output file for ex56_1 on my imac). Please take a look at the differences. If the outputs are correct, I will remove option '-ex56_dm_view'
>>>>> Hong
>>>>> On Sun, Nov 5, 2017 at 9:03 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> Mark:
>>>>>> Bug is fixed in branch hzhang/fix-submat_samerowdist
>>>>>> https://bitbucket.org/petsc/petsc/branch/hzhang/fix-submat_s
>>>>>> amerowdist
>>>>>> I also add the test runex56. Please test it and let me know if there
>>>>>> is a problem.
>>>>>> Hong
>>>>>> Also, I have been using -petscpartition_type but now I see
>>>>>>> -pc_gamg_mat_partitioning_type. Is -petscpartition_type depreciated
>>>>>>> for GAMG?
>>>>>>> Is this some sort of auto generated portmanteau? I can not find
>>>>>>> pc_gamg_mat_partitioning_type in the source.
>>>>>>> On Thu, Nov 2, 2017 at 6:44 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> Great, thanks,
>>>>>>>> And could you please add these parameters to a regression test? As
>>>>>>>> I recall we have with-parmetis regression test.
>>>>>>>> On Thu, Nov 2, 2017 at 6:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>>> Mark:
>>>>>>>>> I used petsc/src/ksp/ksp/examples/tutorials/ex56.c :-(
>>>>>>>>> Now testing src/snes/examples/tutorials/ex56.c with your options,
>>>>>>>>> I can reproduce the error.
>>>>>>>>> I'll fix it.
>>>>>>>>> Hong
>>>>>>>>> Hong,
>>>>>>>>>> I've tested with master and I get the same error. Maybe the
>>>>>>>>>> partitioning parameters are wrong. -pc_gamg_mat_partitioning_type is new to
>>>>>>>>>> me.
>>>>>>>>>> Can you run this (snes ex56) w/o the error?
>>>>>>>>>> 17:33 *master* *= ~*/Codes/petsc/src/snes/examples/tutorials*$
>>>>>>>>>> make runex
>>>>>>>>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 4
>>>>>>>>>> ./ex56  -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2
>>>>>>>>>> -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>>>>>>>>>> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
>>>>>>>>>> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10
>>>>>>>>>> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
>>>>>>>>>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -ksp_converged_reason
>>>>>>>>>> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>>>>>>>>>> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
>>>>>>>>>> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
>>>>>>>>>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type
>>>>>>>>>> jacobi -pc_gamg_mat_partitioning_type parmetis -mat_block_size 3 -matrap 0
>>>>>>>>>> -matptap_scalable -ex56_dm_view -run_type 1 -pc_gamg_repartition true
>>>>>>>>>> [0] 27 global equations, 9 vertices
>>>>>>>>>> [0] 27 equations in vector, 9 vertices
>>>>>>>>>>   0 SNES Function norm 122.396
>>>>>>>>>>     0 KSP Residual norm 122.396
>>>>>>>>>>   <snip>
>>>>>>>>>>   depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
>>>>>>>>>> [0] 4725 global equations, 1575 vertices
>>>>>>>>>> [0] 4725 equations in vector, 1575 vertices
>>>>>>>>>>   0 SNES Function norm 17.9091
>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object type
>>>>>>>>>> [0]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>>>>>> On Thu, Nov 2, 2017 at 1:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>>>>> Mark :
>>>>>>>>>>> I realize that using maint or master branch, I cannot reproduce
>>>>>>>>>>> the same error.
>>>>>>>>>>> For this example, you must use a parallel partitioner,
>>>>>>>>>>> e.g.,'current' gives me following error:
>>>>>>>>>>> [0]PETSC ERROR: This is the DEFAULT NO-OP partitioner, it
>>>>>>>>>>> currently only supports one domain per processor
>>>>>>>>>>> use -pc_gamg_mat_partitioning_type parmetis or chaco or ptscotch
>>>>>>>>>>> for more than one subdomain per processor
>>>>>>>>>>> Please rebase your branch with maint or master, then see if you
>>>>>>>>>>> still have problem.
>>>>>>>>>>> Hong
>>>>>>>>>>>> On Thu, Nov 2, 2017 at 11:07 AM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Mark,
>>>>>>>>>>>>> I can reproduce this in an old branch, but not in current
>>>>>>>>>>>>> maint and master.
>>>>>>>>>>>>> Which branch are you using to produce this error?
>>>>>>>>>>>> I am using a branch from Matt. Let me try to merge it with
>>>>>>>>>>>> master.
>>>>>>>>>>>>> Hong
>>>>>>>>>>>>> On Thu, Nov 2, 2017 at 9:28 AM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> I am able to reproduce this with snes ex56 with 2 processors
>>>>>>>>>>>>>> and adding -pc_gamg_repartition true
>>>>>>>>>>>>>> I'm not sure how to fix it.
>>>>>>>>>>>>>> 10:26 1 knepley/feature-plex-boxmesh-create *=
>>>>>>>>>>>>>> ~/Codes/petsc/src/snes/examples/tutorials$ make
>>>>>>>>>>>>>> PETSC_DIR=/Users/markadams/Codes/petsc
>>>>>>>>>>>>>> PETSC_ARCH=arch-macosx-gnu-g runex
>>>>>>>>>>>>>> -n 2 ./ex56  -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it
>>>>>>>>>>>>>> 2 -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>>>>>>>>>>>>>> -mg_levels_pc_type jacobi -petscpartitioner_type simple -mat_block_size 3
>>>>>>>>>>>>>> -matrap 0 -matptap_scalable -ex56_dm_view -run_type 1 -pc_gamg_repartition
>>>>>>>>>>>>>> true
>>>>>>>>>>>>>>     1 KSP Residual norm 20.4696
>>>>>>>>>>>>>>     2 KSP Residual norm 3.95009
>>>>>>>>>>>>>>     3 KSP Residual norm 0.176181
>>>>>>>>>>>>>>     4 KSP Residual norm 0.0208781
>>>>>>>>>>>>>>     5 KSP Residual norm 0.00278873
>>>>>>>>>>>>>>     6 KSP Residual norm 0.000482741
>>>>>>>>>>>>>>     7 KSP Residual norm 4.68085e-05
>>>>>>>>>>>>>>     8 KSP Residual norm 5.42381e-06
>>>>>>>>>>>>>>     9 KSP Residual norm 5.12785e-07
>>>>>>>>>>>>>>    10 KSP Residual norm 2.60389e-08
>>>>>>>>>>>>>>    11 KSP Residual norm 4.96201e-09
>>>>>>>>>>>>>>    12 KSP Residual norm 1.989e-10
>>>>>>>>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 12
>>>>>>>>>>>>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
>>>>>>>>>>>>>> iterations 1
>>>>>>>>>>>>>> DM Object: Mesh (ex56_) 2 MPI processes
>>>>>>>>>>>>>>   type: plex
>>>>>>>>>>>>>> Mesh in 3 dimensions:
>>>>>>>>>>>>>>   0-cells: 12 12
>>>>>>>>>>>>>>   1-cells: 20 20
>>>>>>>>>>>>>>   2-cells: 11 11
>>>>>>>>>>>>>>   3-cells: 2 2
>>>>>>>>>>>>>> Labels:
>>>>>>>>>>>>>>   Face Sets: 5 strata with value/size (1 (2), 2 (2), 3 (2), 5
>>>>>>>>>>>>>> (1), 6 (1))
>>>>>>>>>>>>>> (2))
>>>>>>>>>>>>>> [0] 441 global equations, 147 vertices
>>>>>>>>>>>>>> [0] 441 equations in vector, 147 vertices
>>>>>>>>>>>>>>   0 SNES Function norm 49.7106
>>>>>>>>>>>>>>     0 KSP Residual norm 49.7106
>>>>>>>>>>>>>>     1 KSP Residual norm 12.9252
>>>>>>>>>>>>>>     2 KSP Residual norm 2.38019
>>>>>>>>>>>>>>     3 KSP Residual norm 0.426307
>>>>>>>>>>>>>>     4 KSP Residual norm 0.0692155
>>>>>>>>>>>>>>     5 KSP Residual norm 0.0123092
>>>>>>>>>>>>>>     6 KSP Residual norm 0.00184874
>>>>>>>>>>>>>>     7 KSP Residual norm 0.000320761
>>>>>>>>>>>>>>     8 KSP Residual norm 5.48957e-05
>>>>>>>>>>>>>>     9 KSP Residual norm 9.90089e-06
>>>>>>>>>>>>>>    10 KSP Residual norm 1.5127e-06
>>>>>>>>>>>>>>    11 KSP Residual norm 2.82192e-07
>>>>>>>>>>>>>>    12 KSP Residual norm 4.62364e-08
>>>>>>>>>>>>>>    13 KSP Residual norm 7.99573e-09
>>>>>>>>>>>>>>    14 KSP Residual norm 1.3028e-09
>>>>>>>>>>>>>>    15 KSP Residual norm 2.174e-10
>>>>>>>>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 15
>>>>>>>>>>>>>>   1 SNES Function norm 2.174e-10
>>>>>>>>>>>>>> iterations 1
>>>>>>>>>>>>>>   type: plex
>>>>>>>>>>>>>>   0-cells: 45 45
>>>>>>>>>>>>>>   1-cells: 96 96
>>>>>>>>>>>>>>   2-cells: 68 68
>>>>>>>>>>>>>>   3-cells: 16 16
>>>>>>>>>>>>>> Labels:
>>>>>>>>>>>>>>   marker: 1 strata with value/size (1 (129))
>>>>>>>>>>>>>>   Face Sets: 5 strata with value/size (1 (18), 2 (18), 3
>>>>>>>>>>>>>> (18), 5 (9), 6 (9))
>>>>>>>>>>>>>>   boundary: 1 strata with value/size (1 (141))
>>>>>>>>>>>>>>   depth: 4 strata with value/size (0 (45), 1 (96), 2 (68), 3
>>>>>>>>>>>>>> (16))
>>>>>>>>>>>>>> type
>>>>>>>>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>> [1]PETSC ERROR: No support for this operation for this object
>>>>>>>>>>>>>> type
>>>>>>>>>>>>>> [1]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>>>>>>> On Thu, Nov 2, 2017 at 9:51 AM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <
>>>>>>>>>>>>>>> rchurchi at pppl.gov> wrote:
>>>>>>>>>>>>>>>> Doing some additional testing, the issue goes away when
>>>>>>>>>>>>>>>> removing the gamg preconditioner line from the petsc.rc:
>>>>>>>>>>>>>>>> -pc_type gamg
>>>>>>>>>>>>>>> Yea, this is GAMG setup.
>>>>>>>>>>>>>>> This is the code.  findices is create with ISCreateStride,
>>>>>>>>>>>>>>> so it is sorted ...
>>>>>>>>>>>>>>> Michael is repartitioning the coarse grids. Maybe we don't
>>>>>>>>>>>>>>> have a regression test with this...
>>>>>>>>>>>>>>> I will try to reproduce this.
>>>>>>>>>>>>>>> Michael: you can use hypre for now, or turn repartitioning
>>>>>>>>>>>>>>> off (eg, -fsa_fieldsplit_lambda_upper_pc_gamg_repartition
>>>>>>>>>>>>>>> false), but I'm not sure this will fix this.
>>>>>>>>>>>>>>> You don't have hypre parameters for all of your all of your
>>>>>>>>>>>>>>> solvers. I think 'boomeramg' is the default pc_hypre_type. That should be
>>>>>>>>>>>>>>> good enough for you.
>>>>>>>>>>>>>>>       IS       findices;
>>>>>>>>>>>>>>>       PetscInt Istart,Iend;
>>>>>>>>>>>>>>>       Mat      Pnew;
>>>>>>>>>>>>>>>       ierr = MatGetOwnershipRange(Pold, &Istart,
>>>>>>>>>>>>>>> &Iend);CHKERRQ(ierr);
>>>>>>>>>>>>>>> #if defined PETSC_GAMG_USE_LOG
>>>>>>>>>>>>>>>       ierr = PetscLogEventBegin(petsc_gamg_
>>>>>>>>>>>>>>> setup_events[SET15],0,0,0,0);CHKERRQ(ierr);
>>>>>>>>>>>>>>> #endif
>>>>>>>>>>>>>>>       ierr = ISCreateStride(comm,Iend-Istar
>>>>>>>>>>>>>>> t,Istart,1,&findices);CHKERRQ(ierr);
>>>>>>>>>>>>>>>       ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>>>>>>>>>>>>>>>       ierr = MatCreateSubMatrix(Pold, findices,
>>>>>>>>>>>>>>> new_eq_indices, MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>>>>>>>>>>>>>>>       ierr = ISDestroy(&findices);CHKERRQ(ierr);
>>>>>>>>>>>>>>>       ierr = PetscLogEventEnd(petsc_gamg_se
>>>>>>>>>>>>>>> #endif
>>>>>>>>>>>>>>>       ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>>>>>>>>>>>>>>>       /* output - repartitioned */
>>>>>>>>>>>>>>>       *a_P_inout = Pnew;
>>>>>>>>>>>>>>>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>> Randy:
>>>>>>>>>>>>>>>>> Thanks, I'll check it tomorrow.
>>>>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>>>> OK, this might not be completely satisfactory, because it
>>>>>>>>>>>>>>>>>> doesn't show the partitioning or how the matrix is created, but this
>>>>>>>>>>>>>>>>>> reproduces the problem. I wrote out my matrix, Amat, from the larger
>>>>>>>>>>>>>>>>>> simulation, and load it in this script. This must be run with MPI rank
>>>>>>>>>>>>>>>>>> greater than 1. This may be some combination of my petsc.rc, because when I
>>>>>>>>>>>>>>>>>> use the PetscInitialize with it, it throws the error, but when using
>>>>>>>>>>>>>>>>>> default (PETSC_NULL_CHARACTER) it runs fine.
>>>>>>>>>>>>>>>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <hzhang at mcs.anl.gov
>>>>>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>>>>>> Randy:
>>>>>>>>>>>>>>>>>>> It could be a bug or a missing feature in our new
>>>>>>>>>>>>>>>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>>>>>>>>>>>>>>>> It would be helpful if you can provide us a simple
>>>>>>>>>>>>>>>>>>> example that produces this example.
>>>>>>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>>>>>> I'm running a Fortran code that was just changed over to
>>>>>>>>>>>>>>>>>>>> using petsc 3.8 (previously petsc 3.7.6). An error was thrown during a
>>>>>>>>>>>>>>>>>>>> KSPSetUp() call. The error is "unsorted iscol_local is not implemented yet"
>>>>>>>>>>>>>>>>>>>> (see full error below). I tried to trace down the difference in the source
>>>>>>>>>>>>>>>>>>>> files, but where the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist())
>>>>>>>>>>>>>>>>>>>> doesn't seem to have existed in v3.7.6, so I'm unsure how to compare. It
>>>>>>>>>>>>>>>>>>>> seems the error is that the order of the columns locally are unsorted,
>>>>>>>>>>>>>>>>>>>> though I don't think I specify a column order in the creation of the matrix:
>>>>>>>>>>>>>>>>>>>>      call MatCreate(this%comm,AA,ierr)
>>>>>>>>>>>>>>>>>>>>      call MatSetSizes(AA,npetscloc,npets
>>>>>>>>>>>>>>>>>>>> cloc,nreal,nreal,ierr)
>>>>>>>>>>>>>>>>>>>>      call MatSetType(AA,MATAIJ,ierr)
>>>>>>>>>>>>>>>>>>>>      call MatSetup(AA,ierr)
>>>>>>>>>>>>>>>>>>>>      call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>>>>>>>>>>>>>>>      allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>>>>>>>>>>>>>>>      call getNNZ(grid,npetscloc,low,high
>>>>>>>>>>>>>>>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>>>>>>>>>>>>>>>      call MatSeqAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>>>>>>>>>>>>>>>      call MatMPIAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
>>>>>>>>>>>>>>>>>>>>      deallocate(d_nnz,o_nnz)
>>>>>>>>>>>>>>>>>>>>      call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>>>>>>>>>>>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>>>>>>>      call MatSetOption(AA,MAT_KEEP_NONZE
>>>>>>>>>>>>>>>>>>>> RO_PATTERN,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>>>>>>> object type
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: unsorted iscol_local is not
>>>>>>>>>>>>>>>>>>>> implemented yet
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0,
>>>>>>>>>>>>>>>>>>>> unknown[62]PETSC ERROR: #1 MatCreateSubMatrix_MPIAIJ_SameRowDist()
>>>>>>>>>>>>>>>>>>>> line 3418 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>>>>>>> 8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line
>>>>>>>>>>>>>>>>>>>> 3247 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
>>>>>>>>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383
>>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>>>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171108/bfb90839/attachment-0001.html>
